Wireguard Help
Hey I’ve tried setting up Wireguard from videos for HA. Using AdGuard too… Everything seems to function except I am not able to get a connection which show transfer rx/tx. I have tried andriod/ PC (which disconnects HA)/tablet… Using UDP port fwd and getting peer notifications… any ideas? Been pulling out my hair that’s left!!
server--
addresses:
192.168.x.x
dns:
172.30.32.1
host: xxx.duckdns.org
peers--
addresses:
192.168.x.x
allowed_ips: []
client_allowed_ips: []
Wireguard Log
[11:12:27] INFO: Requesting current status from WireGuard…
interface: wg0
public key: IbBTetSkPnkxxxxxxxO3YDS+JDRU=
private key: (hidden)
listening port: 51820
peer: KRTOBoqt2VQSHhkxxxxxxxB4QVMTI=
allowed ips: 192.xxx.x.xxx/32
persistent keepalive: every 25 seconds
The client side log/error might be useful to help you solve that.
Even server side logs
Hey thanks… I added to original post
There’s no errors displayed.
The first thing I would check if is the client can reach the server, can you access HA from your client?
Is your NAT correctly set?
Hey thanks for responding
I can reach via using wifi (which I guess should) but not cell data
My NAT is configured for my PS4, if that helps lol
I’ve checked my anti-virus and firewall.
You should check depending on your router (maybe the one your ISP gave you) how to manually forward a port.
Be sure to have dedicated static IP or you’ll need dynamic DNS or reverse proxy.
