I am a fairly new user of HA. I have it running on a RPi4 since June. I also set up the wireguard add-on back then without problems. I use DuckDNS (which is updated with the DuckDNS add-on in HA), and obviously a port forward on my router.
This all worked perfectly. I was able to VPN from my Android-phone to Wireguard, and use HA (but also regular internet) through that tunnel. But since some time, this setup doesn’t work anymore.
I can connect to the VPN on my phone. It will state is connected, but I will get no response. When I look at the connection-details on my phone, I see the connection-time and sent packets increase, but packets received remains at zero. In the Wireguard-log in HA, all I see are entries like this:
[17:49:49] INFO: Requesting current status from WireGuard...
interface: wg0
public key: (removed)
private key: (hidden)
listening port: 51820
peer: (removed)
allowed ips: (removed)
persistent keepalive: every 25 seconds
I do install updates regularly, so I am on the latest HA and Wireguard-addon version.
Does anybody have any idea how I can start investigating, or does someone have experience with this kind of issue?
