I am trying to understanding how ESPHome → Install → Wirelessly works.
For my test.yaml device, I can get these to work:
- Plug into this computer
- This impressed me as this computer is on a different LAN than the computer running Homeassistant/ESPhome,.
- Manual download (and then flash in with USB to TTL interface)
This will not work (expected)
- Plug into the computer running ESPHome dashboard
Note: the compter running ESPHome dashboard is NOT on same LAN as the ESPHome device
If I try:
- Wirelessly
Get these errors:
INFO Successfully compiled program.
INFO Resolving IP address of test.local
ERROR Error resolving IP address of test.local. Is it connected to WiFi?
ERROR (If this error persists, please set a static IP address: https://esphome.io/components/wifi.html#manual-ips)
ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
My assumption is that the computer trying to resolve test.local is the (remote) computer running the ESPHome dashboard; not the computer I am sitting at (which IS on the same LAN as my test device).
Can someone confirm?
If so … then some sort of hint that Wireless OTA installations will not work if the Device is not on same LAN as the computer running Homeassistant/ESPHome.
