Wireless Watering System - LinkTap
Thanks for your help, I finally figured out the problem.
The LinkTap Gateway and one of my Shelly H&T sensors had ended up on the same IP address.
This is because the Shelly H&T sensors, with a fixed IP address) goes to sleep only wakes up when the temperature/humidity changes, despite being on USB Power (not battery).
This means my Router thinks that address is free whilst off and allows devices to use the fixed IP address via DHCP. When the Shelly H&T wakes up it is on the same IP address and of course all hell breaks loose.
Anyway I have taken the Shelly off of a fixed IP and forced the LinkTap Gateway to a fixed IP so hopefully the router won’t give it to something else!
So, thanks again, if I had not used this integration I would have been none the wiser, the LinkTap App and the LinkTap MQTT Integration didn’t report any issues.
Since I have fixed this, the integration has been rock solid.
No worries glad you got it sorted.
Mqtt messages definitely would have been missed, but its likely you never noticed as when it reconnected it would have picked up the messages and done its thing.
And the mobile app certainly isnt the most responsive thing.
Just getting back to this, when I use the following automation action now it is set to seconds it throws an error when I run it
automation
service: linktap.start_watering
  entity_id: valve.linktap_pots
  seconds: 300
Error
Stopped because an error was encountered at March 8, 2024 at 3:41:17 PM (runtime: 1.19 seconds)
extra keys not allowed @ data[‘seconds’]
Answered my own question, seems this issue was fixed in Version 5.3, I was still on 5.2. It works now.
I prefer to use DHCP reservations on the router. I rarely use Fixed IPs (set on the devices), but if I do, I make sure the fixed IPs that I use are outside the router’s DHCP address range.
Hi
Installed the http api integration
Insert my linktap ip adress
I get a ‘fail to configure’
Maybe i need to setup properly the taplonk hub?
Any advice
Xavier
Hi, can anyone confirm that it works (or not) with ZHA? I have already a full smart home build on that, so it would be massively inconvenient to switch to MQTT.
Thanks and cheers
I don’t think you understand the device. LinkTap is proprietary zigbee. It does not work over ZHA or Zigbee2mqtt. It communicates with a LinkTap hub. Within the hub, there is an MQTT client, which you can setup to communicate with your mqtt server if you have one, and that is how entities and control get in to home assistant. Alternatively, there’s a really nice, local, http integration here that doesn’t require mqtt or anything else. I’ve used both connection methods and they both work very well. The LinkTap system itself is top notch. Its nice to see status and such in Home Assistant, but the LinkTap app is really nice, and once the schedule is set, its all done locally, so its really a set it and forget it type of thing. I love the local Home Assistant integration, but I really wouldn’t miss it if the integration didn’t exist. It would still do everything you need to do.
That’s very helpful thank you. Yeah I knew it’s going though the hub, but I assumed that an mqtt client would communicate through zigbee and that’s how I could receive information. The http integration resolves the issue though. Yeah I will probably set it up on the app and let it run, but I wanted to integrate it with my weather station and create automations, like: no automated watering after a rain event and so on.
Cheers
FWIW i wrote the http integration, but I still use the Linktap app for scheduling. I mostly created it because i didnt like that via the mqtt integration you couldnt do water for x, in the same way the native app did.
Turns out you actually can do this via MQTT, they have a more advanced mqtt method, but by the time i configured it all, the HTTP API was less effort and more usable for others.
I have all my schedules setup in the linktap app, along with their skipping feature based on weather data.
I use home assistant for one off things, manual extra watering, because i find the app historically had issues keeping the schedule setup when doing additional manual watering.
I had also planned to use the pause service to focus on historical rainfall … if I have had xx rain over the last few days, pause the tap. I never got around to setting this up, but I have all the pieces in place now.
Is there anyway to change watering plans from Home Assistant?
I have a few watering plans saved in the hub that I would like to change to base on seasons.
I’ve seen the “Plan SN” with a number like 79,808,167 which looks like the kind of thing I’m looking for but I have no idea how to use it.
Thanks,
Pablo
The local API allows you to define a schedule, but not enable / disable an existing one in the same way the app does. These schedules are also not replicated to the mobile app.
I made the call that its easier to either handle scheduling in the linktap app, or to use HA automations. It makes more sense to me that way.
