Wiring for 2 gang smart switch UK
I’ve been following Home Assistant for a couple of months and finally made the move, installed on a Raspberry Pi over the weekend and made some automation with the various smart plugs and power strips I have.
I received the following 2 gang smart switch . I would like to make sure about the right wiring.
Here you can see the current wiring (not the smart switch here):
One of the switches is turning on the light, the other one a fan in the wall. I’m guessing that I’m facing a no neutral wire configuration but would like to make sure.
And if correct, I would have to add the capacitor between the N and L at the light, and regarding to replace this switch with the smart switch, the cable on both common should be targeting the L, while the 2 on the left will go on L1 and L2 in the smart switch.
Correct?
Your neutral wires are the blue ones in the wago connector in the background.
To be honest if you didn’t already know what i told you, you should call an electrician.
