Wiring water level probe with Shelly Uni Plus
Hello, I have a problem wiring my hydrostatic probe with the Shelly uni plus. I need to get the tension (Voltage) of the probe. There is manual with the probe so I’m confused.
The probe comes with three wires, a red, a green and a yellow.
At the moment I have this setup:
Probe: red wire > with > Shelly red wire (+Neutral)
Probe, green > Shelly, green, black (+ground)
Probe, yellow > Shelly, white
The Shelly works and is sending 0 data with Power and Energy (both I don’t need), but nothing about Voltage.
Thank you for your help!
How are you powering the Shelly Plus Uni? Does the sensor have sufficient voltage?
I encountered an issue with an impulse sensor that was supposed to work at 5V but actually needed a higher voltage to produce a clean signal. You might need more power as well. Could you measure the voltage change at the sensor, specifically between the green ground and the yellow output wires?
