Wiser Schneider
I’ve tried to use the iTRVs with SmartThings before and Z2M after. There were mixed results. Recently I started to use them with the Heat Hub and it works far more better. I guess that would work the same way with the Gateway as well. The discussion in the other topic seems to say the same.
Hello, do you know if this will work with the German Merten Wiser Touch? Apparently Schneider purchased these guys as well. The system I have is this one: Wiser™ Home Touch | Merten
If not, does anyone know of an integration for HA?
Thanks!
Sorry I missed your message.
I do not know but if this is recent then I doubt it will be compatible.
However the Drayton Wiser Home Assistant Integration might be a better option for compatibility.
Regards,
Thanks, I will check into it further. The Merten Wiser Home Touch is similar and looks identical in appearance but I think it might have different software. I will contact Merten to see if they have any integration software. - Frank
I contacted Merten and they stated it’s not zigbee but didn’t say what it is. Anyone?
Great post. We’re in the same process although we might not be as far along as you are(architect first draft). Don’t like Plejd at all and other solutions does not seem as developed or one would have to pick and mix between a multitude of brands. Found Wiser the other day while scrolling different solutions for wall outlets(also swedish, seems it’s mostly heaters abroad). Whatever your findings, please share. Following the progress!
One thing I learned is that Schneider can be different in each country. I’m not sure why, but that’s what they disclosed to me. For instance, Schneider Germany and Austria can be different for some reason. I think the switches are BLE & WLAN but not sure how to talk to the gateway. It has an IP address. I would love to keep the gateway since I already paid for it! :slight_smile:
The Wiser Heating devices are not listed as Zigbee devices either. Their brochure says 2.4Ghz only.
As it is not saying Zigbee (Certified), they don’t have to follow fully the standard.
Only the Wiser “legacy” (older) devices used Zigbee, so do a search on Blakadder’s Zigbee database:
https://zigbee.blakadder.com/search.html
So more on this. The shutter devices I am using ARE Zigbee and the Merten Wiser Touch is a Zigbee hub that communicates with them. There is a Alexa skill that is available. That being the case, can I somehow control from HA via Alexa?
I have paired several devices directly via ZHA but the open/close direction and “run-time” for the devices are not implemented very well in the current device quirks.
I’m just looking for a way to send commands from HA to Wiser Touch via Alexa? Is this possible?
Appreciate feedback.
There is a way to trigger Alexa Routines from Home Assistant, like this:
Create the buttons as helpers in Home Assistant, set them up as it required by Alexa for Proactive Events.
Create Alexa routines to trigger the Wiser Touch commands.
Thank you for the insight. I was able to accomplish the same thing just by using the Amazon media player and building a skill within the Alexa app. The solution you gave indeed looks very powerful and hopefully, someday, I’ll have better skills and will do many things this way.
Thank you!
The best thing would be if the Merten Wiser Touch could be added as an integration but it depends on Merten and some people’s interest to invest into it
Suggest reporting that as bug(s) to ZHA Device Handlers → https://github.com/zigpy/zha-device-handlers/issues
The reason why is explained in ZHA docs → https://www.home-assistant.io/integrations/zha#zha-exception-and-deviation-handling
Thanks for the suggestions. I found a way “around” this by using the Alexa media player and issuing commands from HA to the Wiser skill. It works but is messy since I don’t really have visibility into the devices through the skill.
I will pursue this as you suggested.
FYI, ZHA device handler quirk development https://github.com/zigpy/zha-device-handlers/pull/1705
also see the related ZHA quirks feature requests for Schneider Electric Wiser Zigbee devices here:
https://github.com/zigpy/zha-device-handlers/issues?q=is%3Aissue+wiser
Thank you!
I have searched the web for an integration with Schneider Wiser Exxact. This is how i found this thread, but I´m not syre that the integration mentioned here (GitHub - asantaga/wiserHomeAssistantPlatform: Platform and related climate/sensors to support the Drayton Wiser Home Heating System) will work with our products.
We have a Wiser Micro Module Light Switch interacting with Wiser Wireless Switch. We use these products for our lighting in the bathroom. Will the integration linked to above work for us? It mentions it supports lights within the wiser hub from Schneider Electric.
I have also found this site: Zigbee Home Automation - Home Assistant and is wondering if this integration is more suitable for our needs.
Thanks in advance!
Which Wiser Hub do you have? Actually some has a publicly available and officially documented API to control the Hub.
The one mentioned in your post, is for the Drayton Wiser Heat Hub .
ZHA can be suitable for your use, but you need then a Zigbee dongle to use with.
ZHA integration or Zigbee2MQTT should work (but either could need custom converters for devices):
or
https://www.zigbee2mqtt.io/ (see https://www.zigbee2mqtt.io/guide/installation/03_ha_addon.html)
For any of those to buy a Zigbee Coordinator USB adapter such as the examples based on CC2652P:
https://community.home-assistant.io/t/iteads-sonoff-zigbee-3-0-usb-dongle-plus-model-zbdongle-p-based-on-texas-instruments-cc2652p-20dbm-radio-mcu-now-sold-for-19-99/340705
ZHA integration and Zigbee2MQTT are somewhat similar to each other though have different pros and cons, so tip is to buy a Zigbee Coordinator USB adapter like CC2652 that is compatible with either, (as Zigbee works you are only able to have one Zigbee solution connected to a single Zigbee Coordinaor).
I also believe Schneider Wiser devices are known to not completely follow Zigbee specifications and in such cases will need a custom converter or ZHA Device Handler (quirk) depending on solution. Read:
https://www.home-assistant.io/integrations/zha/#knowing-which-devices-are-supported
and
https://www.home-assistant.io/integrations/zha/#zha-exception-and-deviation-handling
For some specific device examples see:
and
https://github.com/zigpy/zha-device-handlers/issues?q=is:issue%2Bwiser
Also note that the ZHA integration does not yet support any ZGP (Zigbee Green Power) based devices:
https://community.home-assistant.io/t/zha-integration-to-get-full-support-for-zgp-zigbee-green-power-devices/277149/
