with Esphome I always get errors here, maybe someone can help
INFO Reading configuration /config/esphome/chickendoor.yaml...
Failed config
cover.template: [source /config/esphome/chickendoor.yaml:49]
platform: template
[open_position] is an invalid option for [cover.template]. Did you mean [open_action], [has_position]?
open_position: 100 [source /config/esphome/chickendoor.yaml:52]
[close_position] is an invalid option for [cover.template]. Did you mean [has_position], [close_action]?
close_position: 0 [source /config/esphome/chickendoor.yaml:53]
[current_position] is an invalid option for [cover.template]. Did you mean [has_position]?
current_position: [source /config/esphome/chickendoor.yaml:55]
- condition: state
entity_id: reed_switch
state: off
position: 0
- position: 100
[open_cover] is an invalid option for [cover.template]. Did you mean [open_action], [on_closed]?
open_cover: [source /config/esphome/chickendoor.yaml:61]
- switch.turn_on: open_cover
[close_cover] is an invalid option for [cover.template]. Did you mean [close_action], [discovery]?
close_cover: [source /config/esphome/chickendoor.yaml:63]
- switch.turn_on: close_cover
[stop_cover] is an invalid option for [cover.template]. Did you mean [stop_action], [discovery]?
stop_cover: [source /config/esphome/chickendoor.yaml:65]
- switch.turn_off: open_cover
- switch.turn_off: close_cover
[set_cover_position] is an invalid option for [cover.template]. Did you mean [has_position]?
set_cover_position: [source /config/esphome/chickendoor.yaml:68]
- service: cover.set_cover_position
entity_id: my_cover
position:
- condition: state
state: off
position: 0
- position: 100
binary_sensor:
- platform: gpio
pin: GPIO12
name: "Chicken Door Reed Switch"
switch:
- platform: gpio
pin: GPIO4
interlock: &interlock [open_cover, close_cover]
- platform: gpio
pin: GPIO5
interlock: *interlock
cover:
open_position: 100
close_position: 0
current_position:
- condition: state
state: "off"
position: 0
- position: 100
open_cover:
close_cover:
stop_cover:
set_cover_position:
entity_id: my_cover
position:
- condition: state
state: "off"
position: 0
- position: 100
