Thanks. That didn’t make any difference.
Below is my export
"id": "581662353c6053e4",
"type": "tab",
"label": "Lights",
"disabled": false,
"info": "",
"env": []
"id": "70122c2cf341f615",
"type": "api-call-service",
"z": "581662353c6053e4",
"name": "Light ON Full",
"server": "7e20b797.b28178",
"version": 5,
"debugenabled": false,
"domain": "light",
"service": "turn_on",
"areaId": [],
"deviceId": [],
"entityId": [
"light.mqtt_light_hue_chinese_laundry_main"
"data": "{\"brightness\":255,\"rgb_color\":[255,255,255]}",
"dataType": "json",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 850,
"y": 40,
"wires": [
"id": "ce3d74b52199e2f8",
"name": "Light ON - Dimm",
"version": 5,
"domain": "light",
"service": "turn_off",
"areaId": [],
"deviceId": [],
"entityId": [
"data": "{\"brightness\":200,\"rgb_color\":[255, 179, 0]}",
"dataType": "json",
"mergeContext": "",
"queue": "none",
"x": 870,
"y": 120,
"wires": [
"id": "87642dd501cd8fe6",
"type": "within-time-switch",
"name": "",
"nameInt": "",
"positionConfig": "b954ab15.fd5738",
"startTime": "07:00",
"startTimeType": "entered",
"startOffset": 0,
"startOffsetType": "none",
"startOffsetMultiplier": 60000,
"endTime": "19:00",
"endTimeType": "entered",
"endOffset": 0,
"endOffsetType": "none",
"endOffsetMultiplier": 60000,
"timeRestrictions": 0,
"timeRestrictionsType": "none",
"timeDays": "*",
"timeOnlyOddDays": false,
"timeOnlyEvenDays": false,
"timeOnlyOddWeeks": false,
"timeOnlyEvenWeeks": false,
"timeMonths": "*",
"timedatestart": "",
"timedateend": "",
"propertyStart": "",
"propertyStartType": "none",
"propertyStartCompare": "true",
"propertyStartThreshold": "",
"propertyStartThresholdType": "num",
"startTimeAlt": "",
"startTimeAltType": "entered",
"startOffsetAlt": 0,
"startOffsetAltType": "none",
"startOffsetAltMultiplier": 60000,
"propertyEnd": "",
"propertyEndType": "none",
"propertyEndCompare": "true",
"propertyEndThreshold": "",
"propertyEndThresholdType": "num",
"endTimeAlt": "",
"endTimeAltType": "entered",
"endOffsetAlt": 0,
"endOffsetAltType": "none",
"endOffsetAltMultiplier": 60000,
"withinTimeValue": "true",
"withinTimeValueType": "msgInput",
"outOfTimeValue": "false",
"outOfTimeValueType": "msgInput",
"tsCompare": "0",
"x": 650,
"y": 60,
"wires": [
"70122c2cf341f615"
"ce3d74b52199e2f8"
"id": "c2bdfd26bd0e907e",
"type": "server-state-changed",
"name": "Chinese Laundry Motion Sensor",
"version": 4,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "binary_sensor.mqtt_sensor_hue_chinese_laundry_occupancy",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "on",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 2,
"output_only_on_state_change": true,
"for": "0",
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 150,
"y": 40,
"wires": [
"0701585584402550"
"id": "0701585584402550",
"type": "api-current-state",
"name": "Good-Bye-Good-Night",
"version": 3,
"outputs": 2,
"halt_if": "on",
"entity_id": "input_button.button_good_night_good_bye",
"blockInputOverrides": false,
"for": "0",
"forType": "num",
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 370,
"y": 140,
"wires": [
"87642dd501cd8fe6"
"id": "7e20b797.b28178",
"type": "server",
"name": "Home Assistant",
"version": 2,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": 30
"id": "b954ab15.fd5738",
"type": "position-config",
"name": "",
"isValide": "true",
"longitude": "0",
"latitude": "0",
"angleType": "deg",
"timeZoneOffset": 99,
"timeZoneDST": 0,
"stateTimeFormat": "3",
"stateDateFormat": "12"
