Withings in bed sensor
I am using a withings sleep tracker for in bed detection
The sensor for in bed detection is no longer against the device.
Is anyone having the same issue or have a suggested work around?
Hi
Just got the sleep analyser mat. I have a whole bunch of sensors downloading, but there is no “in-bed” sensor.
Is this something missing from the latest Withings software or is the HA integration ot pickign it up? Apparently they are claiming you can still trigger automations using IFTTT, so it should be working.
Still working fine for me. Maybe it is disabled by default and you should enable it from device settings?
One thing to realize though: it is the only sensor that depends on webhooks, so if these are blocked or removed this is the only sensor that would stop working. The other thing to note is (but those who used it longer know) that the sensor is unavailable after a reboot, until the bed sensor is activated by going to bed. It should take just a couple of seconds to register. So unavailable is not always indicative of an error.
Apparently webhooks are the problem — I do not my HA out on the public internet. I need to think whether I want the bed sensor more than being safely behind a VPN…
