I’m considering buying Withings smart scale to integrate with HomeAssistant (so we can check weight graphs etc using same UI as everything else). I can see there is a ready integration, but does it support multiple users? From cursory glance at the code, I do not see a place where it would output multiple entities per user, but I might be mistaken. At same time, withings mobile app seems to support it, but maybe it is UI-only filtering based on the weight range.
Cannot test it myself, as I haven’t bought the scale yet - if this is not supported, I might choose different solution (cheaper scale + some kind of DIY bluetooth integration).
