I am trying to get my Withings scale integration working but having trouble. I followed the instructions on the integration page (Withings - Home Assistant) but to no avail.
I am using duckdns for my external domain link rather than nabucasa and I haver set my external domain to the duckdns address (in the UI config rather than on the YAML file)
Here is what I have set up in my yaml file:
# Withings
withings:
client_id: MYCLIENTID
client_secret: MYSECRET
use_webhook: true
logger:
default: warning
logs:
homeassistant.components.withings: debug
When I look at the logs here is the error messages:
2022-01-12 22:41:41 DEBUG (MainThread) [homeassistant.components.withings] Configuring withings webhook
2022-01-12 22:41:41 DEBUG (MainThread) [homeassistant.components.withings] Subscribing https://myexternaldomain.duckdns.org:8123/api/webhook/25f2a98f6ba4197cd15a418173b017900d14b7e7ca8c380bb006a8b4 for NotifyAppli.WEIGHT in 5.0 seconds
2022-01-12 22:41:45 ERROR (MainThread) [homeassistant.components.withings] Unexpected error fetching subscription_update_coordinator data: Error code 293
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 187, in _async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 147, in _async_update_data
return await self.update_method()
File "/usr/src/homeassistant/homeassistant/components/withings/common.py", line 660, in async_subscribe_webhook
return await self._do_retry(self._async_subscribe_webhook)
File "/usr/src/homeassistant/homeassistant/components/withings/common.py", line 656, in _do_retry
raise exception
File "/usr/src/homeassistant/homeassistant/components/withings/common.py", line 649, in _do_retry
return await func()
File "/usr/src/homeassistant/homeassistant/components/withings/common.py", line 702, in _async_subscribe_webhook
await self._hass.async_add_executor_job(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/local/lib/python3.9/site-packages/withings_api/__init__.py", line 311, in notify_subscribe
self.request(path=self.PATH_NOTIFY, params=params)
File "/usr/local/lib/python3.9/site-packages/withings_api/__init__.py", line 78, in request
return response_body_or_raise(
File "/usr/local/lib/python3.9/site-packages/withings_api/common.py", line 825, in response_body_or_raise
raise InvalidParamsException(status=status)
withings_api.common.InvalidParamsException: Error code 293
2022-01-12 22:41:45 DEBUG (MainThread) [homeassistant.components.withings] Finished fetching subscription_update_coordinator data in 19.522 seconds (success: False)
2022-01-12 22:41:47 ERROR (MainThread) [homeassistant.components.withings] Unexpected error fetching subscription_update_coordinator data: Error code 293
It seems to be showing an error code 293 which other people have encountered but I their issues seem to be a bit different to mine.
I did some other research which seemed to indicate that the redirect uri on the withings side will only accept port 443 or 80 whereas home assistant is operating on port 8123. On the error logs it is showing that the webhook API isusing port 8123 but I have gone back and checked that the uri on my withing developer app does not have the port number included.
Any assistance would be appreciated.
Gavin
