Withings sleep used for presence detection
Is it possible to use the sensor to trigger in an out of bed automations?
Will this work without webhooks? My network is not reachable from the outside and I guess this would be needed for webhooks.
The withings in-bed detection is relyant on webhooks, and with the current integration I couldn’t get it to work anyway. I finally used IFTTT as a workaround, but that is not an option if Home Assistant is not exposed to the outside world. I use Nabu Casa cloud for that.
So, there is no way to get that data locally?
There might be another solution, though:
I read that the integration polls every 10 minutes for the state if no webhook is available.
If this time could be shortened in times I might actually go to sleep/wake up it would be perfect.
For example if at home, trigger every minute in the evening and in the morning. I usually don’t sleep at day, so I don’t have to poll.
No, every sensor works, but the in_bed sensor remains unavailable. It is not updated though polling. Also, if you poll too much, the Withings service may hit a rate control limit. As far as I know there is no local API, only though the Withings cloud service.
Withings does state that the sleepmat goes off wifi if you’re on it, so maybe checking it’s IP is possible, but I haven’t tried and I do not know if it is online all the time when you’re not in bed either.
I recently bought a Sleep Analyzer to detect if I am in bed or not. Like Edwin I had no success with the Withings integration in HA and used IFTTT instead. The problem is that it takes around 15-20 secs to update the state (in or not in bed). I think the delay comes from the sensor itself and not IFTTT.
Like Edwin suggested you may could check if the mat is connected to your LAN in order to check its state.
Is anyone else having the same experience with the delay?
I was recently able to get the webhook set-up working (even without Nabu Casa), find more details here: Struggling to get Withings integrations fully operational - #18 by wilcymay
I created a bed precense sensor from other sensors that the withings sleep analyser gives me as sensors. Setting up was a breeze and use this for my sleep alarm triggers etc…
    sensors:
      bed_presence:
        friendly_name: "Bed Presence"
        value_template: >-
          {% if states('sensor.withings_deep_sleep')|float == 0 or states('sensor.withings_light_sleep')|float == 0 %}
            In Bed
            Out of Bed
        icon_template: >-
            mdi:bed-empty
            mdi:bed
        availability_template: >-
          {{ states('sensor.withings_deep_sleep') not in ['unknown','unavailable'] }}
This is my automation that happens when i go sleeping. But it is pretty complex and not usefull for eveyone. This automation triggers when motion is detected in the bedroom and waits until you’re in bed to start a bedtime routine with actions like dimming lights, setting the alarm, and adjusting the climate in the bedroom.
alias: Alarm - Arm Slapen (Verbetering)
description: ""
triggers:
  - type: motion
    device_id: 25f786d6d9adde077aa6274293af2db4
    entity_id: binary_sensor.bewegingssensor_slaapkamer_motion
    domain: binary_sensor
    trigger: device
conditions:
  - condition: time
    after: "21:00:00"
    before: "02:00:00"
  - condition: state
    entity_id: switch.adaptive_lighting_sleep_mode_default
    state: "off"
  - condition: state
    entity_id: input_boolean.aanwezig
    state: "on"
  - condition: state
    entity_id: input_boolean.bezoekersmode
    state: "off"
  - condition: state
    entity_id: input_boolean.net_thuis
    state: "off"
  - condition: numeric_state
    entity_id: sensor.switch_pc_current_consumption
    below: 20
  - condition: state
    entity_id: input_boolean.net_slapen
    state: "off"
actions:
  - data:
      volume_level: 0.2
      entity_id: media_player.slaapkamer
    action: media_player.volume_set
  - data:
      message: Slaapwel, Alarm wordt ingeschakeld binnen 15 minuten
    action: tts.cloud_say
  - target:
    data: {}
    action: input_boolean.turn_on
  - data:
      brightness: 255
      rgb_color:
        - 255
        - 147
        - 41
    action: light.turn_on
      entity_id:
        - light.lamp_slaapkamer
        - light.tafellamp_slaapkamer
  - data:
      temperature: 15
      time_period: "1:00:00"
      device_id: cc4136805d8c8149fe8feec4297bab44
    enabled: true
    action: tado.set_climate_timer
  - data: {}
      device_id: 0310e157837a7eec45a98089e706f4fb
    action: media_player.turn_off
  - if:
      - type: is_temperature
        condition: device
        entity_id: sensor.verwarming_slaapkamer_temperature
        domain: sensor
        below: 16
        entity_id: sensor.buienradar_temperature
        below: 10
    then:
      - type: turn_on
        device_id: 33572bc7db6b48656ebbe43f079e1372
        entity_id: f539dd1c4f822270aec1fa74a49b49c9
        domain: switch
  - data: {}
      entity_id:
        - input_boolean.koken
        - input_boolean.tuin_tuinhuis
        - input_boolean.baden_douchen
    action: input_boolean.turn_off
  - wait_for_trigger:
      - entity_id:
          - binary_sensor.slaapkamer_bewegingssensors
        to: "off"
        for:
          hours: 0
          minutes: 2
          seconds: 0
        trigger: state
        enabled: false
      - trigger: state
        entity_id:
          - sensor.bed_presence
        to: In Bed
        for:
          hours: 0
          minutes: 0
          seconds: 30
  - data:
      brightness: 255
      rgb_color:
        - 255
        - 147
        - 41
      transition: 60
      entity_id:
  - delay:
      minutes: 1
  - repeat:
      count: 10
        - target:
            entity_id:
            brightness: |
              {{ (255 - (repeat.index * 10)) | int }}
            rgb_color: |
                max((255 - (repeat.index * 14)) | int, 120),
                max((147 - (repeat.index * 12)) | int, 27),
                max((41 - (repeat.index * 4)) | int, 0)
            transition: 60
        - delay:
            minutes: 1
  - repeat:
      count: 5
        - target:
            entity_id:
            brightness: >
              {{ max((brightness | default(255) - (repeat.index * 31)) | int, 0)
            transition: 60
        - delay:
            minutes: 1
  - delay:
      minutes: 1
  - target:
      entity_id:
    action: light.turn_off
    data: {}
  - target:
      entity_id: alarm_control_panel.thuisalarm
    data: {}
    action: alarm_control_panel.alarm_arm_away
  - data: {}
    action: switch.turn_on
  - metadata: {}
    data: {}
  - data: {}
      entity_id:
        - automation.heu_color_alarm
        - automation.alarm_trigger_lampen_sirene
        - automation.new_automationalarm_trigger_lampen
        - automation.alarm_trigger_sound
        - automation.wake_up_alarm_with_music
        - automation.wake_up_light_alarm_with_sunrise_effect
    action: automation.turn_on
  - data: {}
      entity_id: script.music_alarm_volume_adjust
    action: script.turn_on
  - data: {}
      device_id:
        - d8b798639261470c4a11369d8962ef40
        - 30dadd1eb7a3645de4341e10b22eda49
        - 4e60105b6e1aad425592f96c133ffa5b
        - 13124f988b62632ca326737a6c4d22d2
        - 37261380c8faffc874808ac4c496f1b3
        - 09224e9eec220f7e4ebe880f8d1aaf39
        - 64dac98bf6970eb809b55f0f4af2466e
        - 494ff120bfb25322f649c38e30bf55aa
        - 25c9c319a00f29ee23f25f2a77cf6e42
      entity_id:
        - switch.switch_slaapkamer_tv
        - switch.switch_slaapkamer_surround
        - switch.switch_slaapkamer_speaker
    action: switch.turn_off
  - data:
      transition: 5
      area_id:
        - gang
        - bureau
        - woonkamer
        - badkamer
        - eetkamer
        - keuken
        - tuin
        - tuinhuis
        - berging
        - gangetje
        - logeerkamer
        - kelder
        - wc
