Can someone give me an example of how to use the number entity to change the effect speed for the Wiz bulbs? The documentation doesn’t help much:
“EFFECT SPEED
The speed of an effect can be controlled via a number entity. The entity will only be available when an effect has been set that allows the speed to be adjusted.”
It tells how it works and what to use but there are no examples for me to understand how to use it. I appreciate your help on this topic.
Did you ever find an answer? I can’t seem to figure it out either. Every other option seems to be available but I can figure out how to adjust the speed of the effect.
Well I just figured out how to make it SOMEWHAT work. There is an ENTITY for Effect Speed. If you click on the entity there is a slider at the top that goes from 10 to 200. Although I think this is more of a global setting for that particular bulb. It would be nice to have the option to set the speed depending on the trigger. Perhaps there is code that can make that happen but I haven’t found it yet.
@PepperHead I feel like such an idiot. Thank you for pointing that slider feature out. It always showed as unavailable. It never occurred to me that it would be unavailable IF there was no effect happening. Once I turned on an effect the slider was suddenly available. Go figure. Now I will try it in a scene and see if that works. Thanks again.
