I tried integrating my light-bulb with home assistant using the WiZ integration, but my lightbulb just doesn’t get detected at all.
I tried using the auto detection method, didn’t work. I tried inputting the id of my lightbulb, also didn’t work.
Allow local communication is turned on. Should I factory reset my lightbulb somehow and use Matter integration, or is there any solution to this issue?
Sorry for the late response, but I just tried to ping the bulb from the HA console. It didn’t get any response. Pinging my phone and laptop worked fine, though. I set up the lightbulb on the same WiFi network so that is a bit strange. I don’t see the lightbulb anywhere on the network admin thing either, but I just assumed that was normal. Could it be that it just set up on a different network, or changed its ip?
