Wiz SmartPlug energy consumption
I’ve just purchased a bunch of Wiz SmartPlugs that can measure the wattage used from whatever is connected to the plug. But it’s not available in the Wiz integration. Only in the Wiz app where you can see energy consumption. I can only turn it on and off, and see network traffic on it.
Will this be supported in a future update?
Thanks!
Same here :slight_smile:
Seems like the consumption is not part of the payload.
Also I thought the plug was ZigBee, but apparently also not supported.
(Wiz SmartPlug energy monitoring)
Bump, and in addition I have asked the Wiz-support to add it to the API too. I mean the power consuption is there measured in their Wiz-app.
I also have ha wiz plug since since time, but it seems that I’m able to show the measured value as such so I guess the basic now work. However, for kicks I tried to add it to the Energy consumption config as an individual unit (the very last box), but it wasn’t listed there, according to the help page that is typically because it doesn’t publish the unit of measurement properly. Could this be fixed?
