I picked one of these up recently and having trouble getting it to work in ESPhome. I thought it may work because W5500 is supported but nothing I try works.
Yet you post so yaml, no logs, no link to the product.
We are not mind readers.
Link to product: https://docs.wiznet.io/Product/iEthernet/W5500/w5500-evb-pico
Here is my yaml:
esphome:
friendly_name: PicoETH
rp2040:
board: rpipicow
# Enable logging
logger:
ethernet:
type: W5500
clk_pin: GPIO18
mosi_pin: GPIO19
miso_pin: GPIO16
cs_pin: GPIO17
interrupt_pin: GPIO21
reset_pin: GPIO20
The yaml complains with this:
You didn’t read the docs did you?
Ethernet Component¶
This ESPHome component enables wired Ethernet connections for ESP32s.
There we are, I even highlighted it for you. And it even says it in your post.
