WLAN Configuration
Hi
I have a strange problem, at least for me. All commands are done via the terminal addon in HASSO.
I do have set a static IP on the ETH0 Interface 192.168.0.225 where the whole routing is working well.
I do have set a static IP on the WLAN0 Interface 192.168.150.225 which I can ping. The gateway is 192.168.150.10 which I also can bing.
I have added a static route 192.168.110.0 via WLAN IP 192.168.150.225. I thought it should be the gateway IP but this is not accepted. Gateway for this subnet is 192.168.110.10 which I can ping as well.
Unfortunately I am not able to ping any other device in this subnet. e.g. ping 192.168.110.11
For example another device (my iPhone) is located in the same WLANsubnet with IP 192.168.150.105 where I am able to ping the subnet 110 as well any device in it.
I am not sure if I have done a or more then one command wrong to give me such issue. I also tried to follow the other post “WLAN configuration hass / raspberry pi 3”. But I can’t see any folder “system-connections” nor the “resin-wifi” file.
Any support is more then welcome. And please be patient with me as I am a Rookie on Linux.
Thanks Markus
HI
is my issue/question so ridicolous that there is nobody that could support me?
Thanks Markus
It’s hard to understand a network setup just with words.
Maybe do a quick drawing so that people can understand where you are and where you would want to be?
thanks and good hint
Please…anybody that can help?
