Hi Everyone,
i’m a total NOOB to RPI and HASS.io. I tried to install HASS.io to my Rasberry Pi 4 and ran into some trouble. I used etcher to flash the 32-bit version of the install software to an SD card and plugged it into my RPI4. I let it run, and it seemed to install,k but after a while I got a repeating error saying ‘…wlan0: link is not ready’ and then after thatn ‘… power save enabled’.
After that it just repeats and I let it go overnight with no result. I was able to access Home Assistant via the ip and port to see my dashboard form another computer. After the first install, Raspian should boot correct? or am I wrong about that? I was under the impression i’d be able to keep using my RPI with Hass running in the background, am I wrong?
if I am able to use both, how do I get away from this wlan error? Thanks all and really sorry if these questions are basic.
A
