WLED and Light effect
Hi there, I have the following automation running based of a google calendar event, it looks at the google calendar uk Holidays for the event Xmas lights if it is found it then triggers the scene. However, what I want to know is as follows below.
How can i change the template value so it checks today’s data against the calendar event and if they do not match then when i press execute to test send a notification to HA saying date not yet reached., yet if the date does match and the event name matches the action fires.
second thing is I want within 1 scene various effects to transition between each other lexample rainbow chase for 3 minutes, then to Christmas light effect next etc.
Thirdly and I would want the lights to come on when the sun is going down etc come on for 4 or 5 hours cycling through the effects. Hope this makes sense. ir can the time be controlled through time settings within google calendar itself.
alias: Calendar lights
  description: Turn on Christmas lights
  - entity_id: calendar.holidays_in_united_kingdom
    platform: state
    to: 'on'
  condition:
  - condition: template
    value_template: '{{is_state_attr(''calendar.holidays_in_united_kingdom'', ''message'',
      ''Christmas Lights'') }}'
  - scene: scene.calendar_lights
  mode: single
  1. Can you clarify?
  2. Use - delay: '00:01:00' in the middle of the scenes.
  3. Use the sun trigger.
Do you have an example yaml file
Look at How to help us help you - or How to ask a good question
is this better
Hi there I have the following condition that is liked to my google calendar which basicaly looks for an event called christmas lights and triggers the action, what i need help with it amend the template or another condition that does the following.
condition: template
I need a template to check today date against against the calendar if no event is present then action will be to not fire the action.
Good morning
Is it possible to create 1 scene with multiple light effects, playing one after the other on a loop etc. for the set period that is in the calendar entity that it trigged from
As my trigger will turn on a light scene with uses WLED and a selected pallet and effect. This scene is activated by an event in my calendar that says Christmas light. And activates if the state of the event is on.
What I want to happen is
The scene runs a rainbow effect for say 3 minutes, then transition to fade effect etc.
