WLED: Change Preset without Turning On
Hello. I currently have WLED setup to read my calendar and update the preset based on the title of the calendar event. However, changing the preset turns WLED on vs leaving it in the current state. My calendar events currently run at 4am, well before it would turn on automatically at sundown. Is there a way to always set it as off or to read the current on/off setting of WLED and use that?
My automation is below. I also provided one of the presets which normally is called at 4am and does not include {“on”: true}".
Thanks!
alias: Change DigiQuad Preset
triggers:
  - trigger: calendar
    entity_id: calendar.wled
    event: start
    offset: "0:0:0"
actions:
  - action: select.select_option
      entity_id: select.dig_quad_v3_preset
      option: "{{state_attr('calendar.wled', 'message')}}"
{"bri":255,"transition":7,"mainseg":0,"seg":[{"id":0,"start":0,"stop":190,"grp":1,"spc":0,"of":0,"on":true,"frz":false,"bri":255,"cct":127,"set":0,"col":[[255,224,160],[255,255,255],[0,0,0]],"fx":0,"sx":128,"ix":128,"pal":3,"c1":128,"c2":128,"c3":16,"sel":true,"rev":false,"mi":false,"o1":false,"o2":false,"o3":false,"si":0,"m12":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0}]}
If this is the only place you apply the preset you could set the brightness in your preset to 0 instead of 255.
Then when turning on your lights at sunrise set the brightness to 255.
I also use WLED Native from my phone to change the presets - so if I set all my presets (minus sunset) to “bri”:0 then I’d have to manually change the brightness each time I make a change.
Can Home Assistant query the current WLED power state, set the preset, and then reset the power state to the previous query value?
Hey @three20three — I ran into this exact issue myself.
When you apply a WLED preset via automation (especially early in the day), it often turns on the LEDs unintentionally — even if "on": true isn’t in your preset, the default behavior in some cases is to power on.
:white_check_mark: Solution:
You can use this custom integration I built:
:link: WLED Live View Proxy for Home Assistant
It lets you send raw WLED JSON API commands via WebSocket, so you have full control. Best part:
You can paste your entire preset JSON (copied from WLED UI), and simply control whether it powers on — dynamically.
:bulb: Example: Apply preset without turning on
action: wled_liveviewproxy.send_command
  targets:
    entity_id:
      - light.wlvp_wled_bead
  command:
      "seg": [{
        "id": 0,
        "start": 0,
        "stop": 100,
        "grp": 1,
        "spc": 0,
        "of": 0,
        "on": "{{ is_state('light.dig_quad_v3', 'on') | lower }}",
        "frz": false,
        "bri": 255,
        "cct": 127,
        "set": 0,
        "col": [[255,0,255],[0,0,128],[255,255,255]],
        "fx": 44,
        "sx": 0,
        "ix": 0,
        "pal": 11,
        "c1": 128,
        "c2": 128,
        "c3": 16,
        "sel": true,
        "rev": false,
        "mi": false,
        "o1": false,
        "o2": false,
        "o3": false,
        "si": 0,
        "m12": 1
:pushpin: This ensures the segment will only turn on if WLED is already on. Otherwise, the effect applies silently without lighting up the strip.
