I have a WLED controlled ledstrip which I control using home assistant.
Most of the time it is showing the ‘Percent’ effect where it is filled partitially (128)
I have multiple automations where this led strip will show a different effect. For example when a call is incoming or when the doorbell is triggered. When the automation finished, it should return to the state it was before. (create snapshot scene, show effect, set snapshot scene again)
The correct effect will be selected again afterwards but the fill percentage is different, in this case value is 164 instead of 128. This means the effect looks completely different.
Is there some way to get this percentage included in the snapshot scene as well?
If so, there is no way to force that automation to update in a scene. However you can trigger it manually after calling the scene restore service using the automation.trigger service.
Thanks for your reply Tom.
I have create a preset in wled woth this effect a d the fill percentage.
When I turn on the light with a button, I simply set the preset for this led strip.
When the doorbell rings, I create a scene as snapshot and I want to activate that snapshot scene afterwards again so it is in the same state. Unfortunately in that case the value will be lost.
Selecting the preset manually again works as expected
