WLED firmware upgrade not selecting the Ethernet version for ESP32-Ethernet module
I’m completely new to HA (installed over the weekend) so I apologize if this is something simple. I ran a firmware upgrade for one of my WT32-ETH01 modules (ESP32 with wired ethernet built-in), and it installed the base ESP32 firmware instead of the Ethernet version that had been previously installed so there was no more Ethernet support and I had to connect it to my WiFi to get back on the device (with a different IP address of course). Is there a way to force HA to use a different binary than the one that it thinks it should be using?
According to the devs it should pick the correct firmware. Can you please open a new issue for this:
Thanks for the reply Tom. I was putting in an issue on the GitHub as requested and decided to try again to take screenshots through the process but this time it worked as it was supposed to. Chalk it up to a fluke I guess.
