I converted some battery operated candles to WLED and mains power for my wife.
I just used the candle effect but I also wanted coloured candles for my granddaughter. I made each candle it’s own segment and then preset with the chosen colour.
I’m happy with the result!
I would like to make the coloured ones shift the colour to the next candle every 5 seconds. Have tried various effects but can’t get the result I’m looking for. I thought a HA script might be the best way to go.
I created this simple script which takes 5 colours as variables.
sequence:
- alias: "Set 1st Bath Candle to 1st colour"
service: light.turn_on
rgb_color: "{{ colour1 }}"
entity_id: light.candle_wled
- alias: "Set 2nd Bath Candle to 2nd colour"
rgb_color: "{{ colour2 }}"
entity_id: light.candle_wled_segment_1
- alias: "Set 3rd Bath Candle to 3rd colour"
rgb_color: "{{ colour3 }}"
entity_id: light.candle_wled_segment_2
- alias: "Set 4th Bath Candle to 4th colour"
rgb_color: "{{ colour4 }}"
entity_id: light.candle_wled_segment_3
- alias: "Set 5th Bath Candle to 5th colour"
rgb_color: "{{ colour5 }}"
entity_id: light.candle_wled_segment_4
I also tried to create an automation that uses an input_select to step through a list of values.
- alias: Change bath candle colours
platform: time_pattern
minutes: '/1'
condition:
condition: state
state: 'on'
- service: light.turn_on
data_template:
colour: "{{ states('input_select.candle_colours') }}"
- service: input_select.select_next
entity_id: input_select.candle_colours
Here is the input_select.
input_select:
candle_colours:
options:
- Green
- Red
- Blue
- Yellow
- Purple
This, of course, doesn’t work but I would like feedback on whether it is possible to change the input_select to create all 5 variables to set the 5 segments each to a different colour.
I thought maybe the script might not even need the input_select if it could simply read the rgb_color of the previous segment and apply that.
Any ideas or suggestions are most appreciated.
