WLED Select Preset and Effect entities unavailable
Hi, I have the WLED integration, but the preset and effects select entities are marked as unavalabile. All other entities created are OK. Is there a way to make these entities available? I would like to add them to lovelace to manually select effects.
I’m assuming it’s the “_playlist" and "_preset” entities you’re referring to. These are unavailable if none are defined in WLED. Open the WLED UI and you can create a selection of both under “Presets”. The effects entries are attributes on the main entity.
Ah! I was confusing the preset list with the effects list. Thanks!
I found effects under the light entity itself.
