WLED Staircase with AI build your own
Hi All,
Manged to get Claude to build me a full WLED staircase setup, so much easier than rolling my own.
I made an interactive demo to go with it so you can see what it does before deciding to install it or getting your own AI to build one.
A full Github repo explaining the full build, circuit layout and custom HA card with presets built off the awesome Bubble Card.
Info:
This project is set to animate the stairs by using and top and bottom step PIR, which is replicated as software buttons on the HA card.
It is set to run at night, which can be overriden by the nighttime mode “moon button”
The 2 hardware button are primarily used for diagnostic and can run the sweep pattern day or night.
There is also a provision that if you arm the house alarm for the downstairs, it will recognise the top step activation and light the stairs in red to alert you that the bottom floor is “armed”
There are also 2 party effects, Matrix and Disco, which works even better if you connect a microphone (not currently built yet)
Video 1
Video 2
