Hope this is the correct place to post this.
I have WLED set up and working well. The issue I have is with the switch used to turn it on/off.
The switch turns LEDs on and off but it is not a toggle.
If I turn on the leds via the switch and the off via another method (Alexa / home assistant) then I have to turn the switch off and the back on to turn the LEDs back on.
Can the switch be set so it is a toggle and one flick of the switch will change the on / off state of the LEDs
Done some googling but no-one seems to mention this
