Wolflink write support
could someone please add the support for writing back to the wolf smartset portal.
The integration works perfectly in ioBroker (with this adapter https://github.com/iobroker-community-adapters/ioBroker.wolf-smartset) but is not working in Home Assistant (Wolf SmartSet Service - Home Assistant it’s unfortunately read only)
It would be great to have the write support for my ism7i module so I can turn on hot water for one hour during the summer times when usually the heating function is set to off and I only need hot water for taking a shower.
Thanks that would be really great.
I am pushing this point ^^. Reading is working fine, but I have similar ideas like handy80.
An alterntative way not using Wolf SmartSet-Portal would be OK, too. The internet access seems to be down for two days now.
Best Regards, Alois
Not exactly what you are asking for, but I am also unsatisfied by the portal integration.
So I am trying this setup via mqtt without internet or portal necessary:
Would also be nice to be able to use a direct connection without the cloud. It is possible in the mobile app.
+1
I would love a writing support!!
This FR from @ChristophKrause is also going into that direction.
There where also these two FR’s from Github
Especially the Experlevel (Fachmann-Ebene) is “only” locked with a Key that is normally set to “1111”. Maybe this is a way to go. I don’t have any programming skills, so can’t really help working it out, but that would be awesome.
Still no write possible. :frowning:
I am wondering to buy either:
  1. ISM7 - WOLF Link home
or
  1. ISM8 WOLF Link pro
This would be used locally via:
  1. GitHub - b3nn0/hassio-addon-ism7mqtt: HomeAssistant Addon for running ism7mqtt to fetch data from Wolf heaters
or
  1. GitHub - marcschmiedchen/home-assistant-wolf_ism8: WOLF ISM8 -- HVAC integration for Home Assistant
Do You know if there are any differences in range of parameters which can be configured between these two options? ISM7 is much cheaper to buy. I am not looking to use it via cloud/app.
Hey Alex, its a little late to answer but for whom it may be of interest - the b3nnos addon “Ism7MQTT Experimental” is working beautifully in my setup, including setting of parameters. I now can control the 1xWarmwasser from within my Victron node-red program flow.
The only thing that I needed to do is to disable the online connection of the smart-set connection. First it looked as if everything is working fine, but after a short period the mqtt-broker stoped receiving updates from ism7… as described in the readme file.
Ism8 with the current firmware also has massive problems with the mqqt breaking of. Had to change back to ism 7 and smartset app. At least I get data there.
Anybody got an idea why nobody is working on this feature?
