Wolflink write support
could someone please add the support for writing back to the wolf smartset portal.
The integration works perfectly in ioBroker (with this adapter https://github.com/iobroker-community-adapters/ioBroker.wolf-smartset) but is not working in Home Assistant (Wolf SmartSet Service - Home Assistant it’s unfortunately read only)
It would be great to have the write support for my ism7i module so I can turn on hot water for one hour during the summer times when usually the heating function is set to off and I only need hot water for taking a shower.
Thanks that would be really great.
I am pushing this point ^^. Reading is working fine, but I have similar ideas like handy80.
An alterntative way not using Wolf SmartSet-Portal would be OK, too. The internet access seems to be down for two days now.
Best Regards, Alois
Not exactly what you are asking for, but I am also unsatisfied by the portal integration.
So I am trying this setup via mqtt without internet or portal necessary:
Would also be nice to be able to use a direct connection without the cloud. It is possible in the mobile app.
+1
I would love a writing support!!
This FR from @ChristophKrause is also going into that direction.
There where also these two FR’s from Github
Especially the Experlevel (Fachmann-Ebene) is “only” locked with a Key that is normally set to “1111”. Maybe this is a way to go. I don’t have any programming skills, so can’t really help working it out, but that would be awesome.
Still no write possible. :frowning:
