ANSWER
I figured out a way to do it.
Here is the flow:
[{"id":"8af7c471.af83c8","type":"server-state-changed","z":"9fa967ab.9b4a38","name":"Guest Bedroom Ceiling Fan","server":"c7cbc76b.fd06a8","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"fan.jasco_products_14287_fan_control_switch_level_2","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":340,"y":1020,"wires":[["450f1b0b.4fe754"]]},{"id":"600b29f1.4bd508","type":"change","z":"9fa967ab.9b4a38","name":"Add a reset flag","rules":[{"t":"set","p":"status.fanAutoReset","pt":"global","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":1020,"wires":[["dcb76551.dd4768"]]},{"id":"146089fe.23c1a6","type":"switch","z":"9fa967ab.9b4a38","name":"Are we resetting to Auto?","property":"status.fanAutoReset","propertyType":"global","rules":[{"t":"null"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":1080,"wires":[["600b29f1.4bd508"],["6d56dec4.c6bd8"]]},{"id":"dcb76551.dd4768","type":"stoptimer","z":"9fa967ab.9b4a38","duration":"2","units":"Second","payloadtype":"num","payloadval":"0","name":"Start a 2 second timer","x":1020,"y":1020,"wires":[["d3fbb636.8481c8"],["9521547.5803aa8"]]},{"id":"d3fbb636.8481c8","type":"change","z":"9fa967ab.9b4a38","name":"Remove Reset Value","rules":[{"t":"delete","p":"status.fanAutoReset","pt":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":1300,"y":1020,"wires":[["c282f75a.654f58"]]},{"id":"6d56dec4.c6bd8","type":"change","z":"9fa967ab.9b4a38","name":"Re-Enable Automation","rules":[{"t":"set","p":"status.fanGuestBedroomManualOverride","pt":"global","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":840,"y":1080,"wires":[["2c7f779.d2b9888"]]},{"id":"2c7f779.d2b9888","type":"change","z":"9fa967ab.9b4a38","name":"Stop Timer","rules":[{"t":"set","p":"payload","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":1080,"wires":[["dcb76551.dd4768"]]},{"id":"c282f75a.654f58","type":"change","z":"9fa967ab.9b4a38","name":"Enable Manual Override","rules":[{"t":"set","p":"status.fanGuestBedroomManualOverride","pt":"global","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1310,"y":1080,"wires":[[]]},{"id":"450f1b0b.4fe754","type":"switch","z":"9fa967ab.9b4a38","name":"Manual Action?","property":"data.new_state.context.user_id","propertyType":"msg","rules":[{"t":"null"}],"checkall":"true","repair":false,"outputs":1,"x":580,"y":1020,"wires":[["146089fe.23c1a6"]]},{"id":"9521547.5803aa8","type":"change","z":"9fa967ab.9b4a38","name":"Remove Reset Value","rules":[{"t":"delete","p":"status.fanAutoReset","pt":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":1300,"y":980,"wires":[[]]},{"id":"c7cbc76b.fd06a8","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
And here’s an explanation:
The first node that I setup, which is not included here, was a function node to initialize an array of global variables, one for each fan, with a simple boolean value.
At midnight every night, all 4 variables are set to false. “Are the fans in manual mode?” No.
Here is the function:
var status = {
"fanKitchenManualOverride" : false,
"fanLivingRoomManualOverride" : false,
"fanGuestBedroomManualOverride" : false,
"fanMasterBedroomManualOverride" : false,
global.set("status", status);
return msg;
Whether or not fans are included in any automations is dependent upon previous conditions set through other flows, so we’re not running fans when fans shouldn’t be running anyway.
Now that we have that variable in place, we can create the individual fan flows to be able to set and unset manual mode based upon actions at the Zwave switch.
Any time someone touches a fan paddle, a flow begins. Here is the logic:
Was this a manual action? If yes, do we have a global reset variable set, or is it null? If it’s null, create a reset variable, then start a timer. If another state change occurs before the timer expires, using the reset variable as a condition, we’ll reset the manual override value to true, stop the timer, and remove the reset variable. If another state change doesn’t occur before the timer expires, we set the manual override status to true for that zwave switch, and remove the reset variable.
So far it seems to work. The next step is to write this up as a single flow instead of duplicating it for each zwave device. After that, figuring out how to manage two potential problems:
- What if HA triggers a fan action while the timer is running?
- What if two people attempt to switch devices to auto mode at the same time?
