Won't Update . .
i’ve need to update the Core and the OS.
Tried on the GUI
Tried with the ha core update command.
but it’s avoid to update . . .
Do i need to ssh into the host to update the docker ?
Will it takes all the settings ?
I have the same problem
What errors are given when the attempt to update fails?
Do you have enough free disk space?
when i use update in GUI no errors
when i update in CLI its only processing and finish.
i have 60% disk space free
this is log , after 10 minutes no progression
20-11-24 10:40:24 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 0.118.3
20-11-24 10:40:24 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:0.115.6 to homeassistant/raspberrypi4-64-homeassistant:0.118.3
20-11-24 10:40:24 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 0.118.3.
Try running the config check addon against the new version.
0-11-24 11:28:26 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/aarch64-addon-check_config:3.5.0 to homeassistant/aarch64-addon-check_config:3.6.0
20-11-24 11:28:26 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-check_config with tag 3.6.0.
20-11-24 11:28:27 ERROR (SyncWorker_1) [supervisor.docker.interface] Can’t install homeassistant/aarch64-addon-check_config:3.6.0 -> 404 Client Error: Not Found (“no such image: homeassistant/aarch64-addon-check_config:3.6.0: No such image: homeassistant/aarch64-addon-check_config:3.6.0”).
20-11-24 11:28:27 INFO (SyncWorker_1) [supervisor.docker.interface] This error is often caused by not having enough disk space available. Available space in /data is: 6.6 GiB
20-11-24 11:28:31 ERROR (MainThread) [supervisor.utils.json] Can’t write /data/addons.json: [Errno 30] Read-only file system: ‘/data/addons.json’
20-11-24 11:28:31 ERROR (MainThread) [supervisor.utils.json] Can’t write /data/addons/data/core_check_config/options.json: [Errno 30] Read-only file system: ‘/data/addons/data/core_check_config/options.json’
20-11-24 11:28:31 ERROR (MainThread) [supervisor.addons.addon] Add-on core_check_config can’t write options
seems you don’t haven enough space on your disk
i think there are lot of tmp files
how can i clean disk ?
Remove old snapshots (or copy them elsewhere). Remove unwanted addons.
1 have one snapshot 25mb
4 addons
now the filesystem is readonly
will reinstall everything this evening
