Hi everyone,
We need a opinion about this code. We want to do an automatic heating system with a circulator, what we can overwrite with a simple physical switch. The automatic heating system should turn on the circulator at 55 celsius and turn off at 48 celsius and when we turn the switch in ON state, the circulator should turn on until the switch is in the off position. BUT the code overwrite it with the celsius based rule.
Thanks for help, and sorry for bad english
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "qKJVefaX914OpcPzNT7uphbcNFcS4HNMuIcohiaunE8="
ota:
password: "4f9bf9cc986cc2909c350a6713227697"
time:
- platform: homeassistant
web_server:
version: 2
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Teszt Fallback Hotspot"
password: "ESw1VneJknhu"
captive_portal:
binary_sensor:
- platform: gpio
pin:
number: GPIO26
mode: INPUT_PULLUP
filters:
- invert:
on_state:
then:
- switch.turn_on: rele
- output.turn_on: zold_led
- output.turn_off: piros_led
spi:
miso_pin: GPIO19
clk_pin: GPIO18
- platform: max6675
cs_pin: GPIO5
update_interval: 5s
on_value_range:
- above: 55
then:
- below: 48
then:
- switch.turn_off: rele
- output.turn_off: zold_led
- output.turn_on: piros_led
switch:
- platform: gpio
pin: GPIO27
inverted: False
output:
- platform: ledc
pin: GPIO17
- platform: ledc
pin: GPIO16
