I’m having connectivity issues with WOOX R7060 irrigation system. I’m using conbee2 with ZHA. By looking at the logs I don’t have any fatal error.
Basically if reconnect the device it works with quite some delay. After couple of hours the device is non longer connecting while showing as connected.
I have similar problem with it. It works for a while but then randomly stops reacting and requires to pair it again .
Sometimes actually reloading ZHA allows me to toggle it but then connection lost again. Only after pairing again it becomes reactive for few hours may 2 days max before issue repeats…
Same issue, WOOX R7060 looses connection to Deconz from time to time.
But works better than ZHA ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 - looses connection more often.
I solved the issues by switching to Sonoff ZBDongle-E and adding more devices acting as a router around it. In my case I used some outdoor light from Philips HUE, without them it wasn’t working. It seems that the R7060 has not an optimal receiver, but now it works
