Wordwrap in automations after saving
Over the past few months I have noticed that my automations.yaml is wrapped at about 81 characters. This does not cause any problems, but it is not very human readable. Is there a way I can turn this off, or perhaps is there a way I can format this to keep things more human readable? Here is an example of how I want it to look:
service: input_text.set_value
  entity_id: input_text.front_door_lock_status
  value: >-
    {% set users = ['Chris','Violet','Pat or Bob','Melanie','Amelia'] %}
	{% set userID = trigger.event.data.parameters['userId'] %}
	{% set user = 'Keypad' if userID == null else users[userID|int -1] %}
	{% if trigger.event.data.event_label == 'Manual unlock operation' %} Manual Unlock
    {% elif trigger.event.data.event_label == 'Manual lock operation' %} Manual Lock
	{% elif trigger.event.data.event_label == 'RF unlock operation' %} RF Unlock
	{% elif trigger.event.data.event_label == 'RF lock operation' %} RF Lock
	{% elif trigger.event.data.event_label == 'Keypad unlock operation' %} Keypad Unlock ({{ user }})
	{% elif trigger.event.data.event_label == 'Keypad lock operation' %} Keypad Lock ({{ user }})
	{% else %} "{{trigger.event.data.event_label}}"
	{% endif %}
Once I edit the automation and save it, this is what I get:
  value: >-
    {% set users = ['Chris','Violet','Pat or Bob','Melanie','Amelia'] %} {% set
    userID = trigger.event.data.parameters['userId'] %} {% set user = 'Keypad'
    if userID == null else users[userID|int -1] %} {% if
    Lock {% elif trigger.event.data.event_label == 'RF unlock operation' %} RF
    Unlock {% elif trigger.event.data.event_label == 'RF lock operation' %} RF
    Lock {% elif trigger.event.data.event_label == 'Keypad unlock operation' %}
    Keypad Unlock ({{ user }}) {% elif trigger.event.data.event_label == 'Keypad
    lock operation' %} Keypad Lock ({{ user }}) {% else %}
    "{{trigger.event.data.event_label}}" {% endif %}
Thanks!
No. You are using the Automation Editor and that’s how it stores whatever you create.
If you don’t want to have your automations re-formatted and you want to include comments in your automations, use a text editor (I use VS Code) and save the file (or files) in a separate location.
There are instructions here for splitting your configuration that allow you to separate automations you create manually with a text editor from those you create with Automation Editor. All the automations will continue to be shown in Configuration > Automations.
Thank you!
