Continuing the discussion from Migrate from HA core to HA operating system (or container image) running in a systemd-nspawn container?:
I’ve been working on my setup for a bit and am pretty happy with it. I intend to write up a whole thing when its ready, but figured I might as well share some work-in-progress which might be helpful for others in the meantime.
Disclaimer: my day job gives me a vested interested in running this on Fedora Linux, but this isn’t an advertisement. I actually started the project to make sure I have some hands-on experience. But I think it’s a great setup and I’m excited to share it with others as well.
I’m also happy for your suggestions for doing things better — I’m new to the Home Assistant scene!
My current setup is running on Fedora Workstation on my desktop, while I hack at it, My eventual plan is to move to Fedora IoT on a Jetson Nano, but I’m still waiting on some bootloader bits to come together before that’s ready.
Computer setup
- As mentioned, running this on a Fedora Workstation system.
- NOTE: I set this up on Fedora Linux 35 with Podman 3.x. I’m told that there may be some issues with the default networking in Podman 4.x in Fedora Linux 36. Figuring that out is on my list.
- Right now, I’m running it all out of my own user account; I intend to move that to using a dedicated
hass
account. An argument could be made for running each of these services in their own account for further isolation. - I’m using systemd and podman to launch and manage the containers.
- I’m using systemd instead of openshift or another kubernetes system because k8s seems like overkill for the situation, and because I’d have to figure out something with the USB devices.
- Podman is generally a drop-in replacement for the more-famous Docker container tooling, but has some nice architectural advantages. It doesn’t require a daemon, and pioneered the idea of running containers as non-root.
- SELinux wraps the containers in further restriction, so a lot of theoretical container-break-out exploits are mitigated without even knowing what they might be.
- While I’d love to have all of the software packaged and integrated natively in Fedora and run Fedora-based containers, most of the software has actively-maintained upstream container images, and I’m using those directly. (I would like to have this all neatly tied up as an “out-of-the-box” thing for Fedora IoT, and for that we probably will want to go through that. Let me know if you’re interested in working on that idea!)
- You’ll also need to add the container user to the
dialout
group:sudo gpasswd -a hass dialout
.- an alternative to this might be a udev rule which sets the permissions to the container user directly. TODO item to investigate that.
Network
- Everything is running on my home private network. Some stuff is on a dedicated IoT subnet, but a lot of devices are annoying about that (“cast” devices, for example, want to be on the same network as people’s phones and computers), so… I’ll have to figure that out.
- I’m using my own domain name, of course, but for the purposes of this demo I’m using
home.example.org
. - My system’s firewall configuration blocks high-port connections except from localhost. Right now, several of the containers are exposed with
--network=host
, but this keeps them blocked off.- Ngnix is running as a reverse proxy, providing access at https://smart.home.example.org.
- So that the Ngnix container can run as non-root, it’s actually bound to 8443 and 8080. The firewall forwards 443 and 80 to those ports.
- To access the zwavejs2mqtt and zigbee2mqtt interfaces right now, I’m temporarily dropping the firewall. I intend to eventually set them up with their own names like https://zigbee.home.example.org (because I’m finding trying to convince them to live at paths like https://smart.home.example.org/zigbee is fragile). TODO.
Controllers and protocol-specific software
- I have a mix of Z-Wave and Zigbee devices in my house, so I’m using both. I started with the Nortek HUSZBZ-1 both-in-one stick, but migrated to separate devices. No real need — that was actually working fine — but that’s not made anymore and uses older generations of both technologies. So:
- For Zigbee:
- I’m using the TubesZB USB coordinator. I started with a Sonoff controller, but decided to make that into an additional router to help with some sensors I’m adding outside. (Future work!). And I love the idea of small-scale devices produced with love by fellow hobbyists.
- I’m using zigbee2mqtt. I wanted to stick with ZHA for less complexity, but ZHA and Ikea Tradfri currently do not play nice so I bit the bullet. I have some other ideas for which MQTT will be helpful, so … probably worth it anyway.
- For Z-Wave:
- I have the Zooz ZST10-700 stick. I updated to the latest firmware before I started with it, and haven’t noticed any of the trouble people have reported with the 700-series controllers, FWIW.
- And using zwavejs2mqtt.
- I was also using Homebridge, but as of today, I’ve switched to the new HA integration from hopefully will have a solution soon — which is nicer in several ways already anyway. If you need homebridge or any other extra service, they can basically be added the same as the zwave and zigbee containers.
Systemd and containers
As mentioned, the containers are all managed by systemd and run in user sessions. The various unit files described in sections below go in ~/.config/systemd/user
in the relevant user’s home directory. (Podman doesn’t currently work non-root containers in the system systemd config.)
You manipulate these with systemctl --user
. For example:
systemctl --user start container-homeassistant
You can also see their combined output with journalctl --user
. This is nice because it ends up putting all of their logs in one place. Note that if you make changes to the config files, you’ll need to do systemctl --user reload
before they take effect.
Important: to keep systemd from stopping all of these containers when you log out, you need to run
loginctl enable-linger hass
… where hass
is the user under which the containers run.
Podman Autoupdate
All of the containers are given a label which tells podman autoupdate that they should be brought to the latest container versions. There’s a timer unit which makes this happen. Run:
systemctl --user enable --now podman-auto-update.timer
to turn this timer on for your user session. (Note that enabling this system-wide will not affect “rootless” containers owned by a user, as this setup uses.)
Directory structure
I’m putting everything under /srv/hass
. Basically all local config goes there, with a subdirectory for each service. I also have the systemd unit files linked there, in /srv/hass/systemd
(so I can edit them without thinking about what particular home directory they’re in), as well as a /srv/hass/secret
directory which holds API keys and such.
Certbot and Let’s Encrypt
I’m running on my home network, and didn’t want to expose systems this directly to the Internet. But I also wanted to use SSL, and a) the Android app won’t work with a self-signed cert and b) it’s better practice to use Let’s Encrypt when possible anyway. Most advice involves setting up dynamic DNS in some way, and making a network ingress path. But, there’s another way: the Let’s Encrypt “DNS challenge”. For this, you need a DNS provider that supports updating records via an API. Fortunately, Digital Ocean provides this — and it’s actually one of their free services. (Digital Ocean is awesome!).
But… Digital Ocean isn’t a domain registrar, and I actually already have most of my systems already all set up using DNS from my registrar. (Pair Domains, by the way. They’re awesome but kind of old-school in their approach, so they don’t have these nifty “cloud” features.) I was thinking I’d have to move everything to Digital Ocean, which would have been a chore — and also a lot of yak shaving. But I realized that DNS, as a technology, actually has a nice solution already. It is designed for heirarchical delegation, after all — so all that’s needed is to delegate some to Digital Ocean.
To do this, at my main registrar, I set up NS
records for home.example.org
home » ns2.digitalocean.com.
home » ns3.digitalocean.com.
home » ns1.digitalocean.com.
Now, any requests for home.example.org
(or names further under that, like smart.home.example.org
) will be sent to Digital Ocean, leaving the rest of example.org
where it is. That way, only the systems related to this will be managed by Digital Ocean, which saves me work and also means that if my Digital Ocean API key is compromised, they can only mess with these hostnames, not my whole domain.
I won’t go into the details of setting up the DNS challenge with Digital Ocean… but here’s the pratical config. It’s entirely done in the systemd units — you don’t need anything else except your dns_digitalocean_token
in /srv/hass/secret/certbot-creds
. The /srv/hass/certbot
directory needs to exist, but you don’t need to have any files there to start. (Running the service will create a bunch of 'em, and those are supposed to persist between runs.)
~/.config/systemd/user/container-certbot.service
[Unit]
Description=CertBot container to renew Let's Encrypt certificates
Wants=network-online.target
After=network-online.target
RequiresMountsFor=%t/containers
[Service]
Environment=PODMAN_SYSTEMD_UNIT=%n
Restart=on-abnormal
RestartSec=3600
TimeoutStopSec=60
TimeoutStartSec=10800
ExecStartPre=-/usr/bin/podman secret create certbot-creds /srv/hass/secret/certbot-creds
ExecStartPre=/bin/rm -f %t/%n.ctr-id
ExecStart=/usr/bin/podman run \
--cidfile=%t/%n.ctr-id \
--cgroups=no-conmon \
--rm \
--sdnotify=conmon \
-a stdout -a stderr \
--replace \
--label "io.containers.autoupdate=registry" \
--name certbot \
--volume=/srv/hass/certbot:/etc/letsencrypt:z \
--secret=certbot-creds,mode=0400 \
certbot/dns-digitalocean -n renew --dns-digitalocean --dns-digitalocean-credentials /run/secrets/certbot-creds --dns-digitalocean-propagation-seconds 3660
ExecStop=/usr/bin/podman stop --ignore --cidfile=%t/%n.ctr-id
ExecStopPost=/usr/bin/podman rm -f --ignore --cidfile=%t/%n.ctr-id
ExecStopPost=-/usr/bin/podman secret rm smart.home.example.org.cert
ExecStopPost=/usr/bin/podman secret create smart.home.example.org.cert /srv/hass/certbot/live/smart.home.example.org/fullchain.pem
ExecStopPost=-/usr/bin/podman secret rm smart.home.example.org.key
ExecStopPost=/usr/bin/podman secret create smart.home.example.org.key /srv/hass/certbot/live/smart.home.example.org/privkey.pem
Type=oneshot
NotifyAccess=all
[Install]
WantedBy=default.target
~/.config/systemd/user/container-certbot.timer
[Unit]
Description=Renews any certificates that need them renewed
Requires=container-certbot.service
[Timer]
Unit=container-certbot.service
OnCalendar=weekly
[Install]
WantedBy=timers.target
And run systemctl --user enable --now container-certbot.timer
. You can also manually run certbot with systemctl --user start container-certbot.service
, which you probably will want to do right away initially. (TODO: you may have to run the container once in non-daemon mode to do the initial setup. I forgot to write this down as I was doing it… will check back and fix this.)
Running this will create a bunch of files under /hass/certbot
. If everything is going smoothly, you should be able to basically ignore that forever, because nothing else will ever need to reference it. The systemd service loads the certificates as podman secrets, which you’ll see in the next section.
Run podman secret ls
to see. The output should look something like:
ID NAME DRIVER CREATED UPDATED
15277f7482f758592a59644ca smart.home.example.org.cert file 5 days ago 5 days ago
a230f0479ca6302f9a87835ff smart.home.example.org.key file 5 days ago 5 days ago
cf9857a57f7005e140c491d34 certbot-creds file 4 weeks ago 4 weeks ago
if everything worked.
Ngnix
This is pretty straighforward really. You just need a config file and the systemd unit. There’s not even a web root involved. I might add some stuff to make pretty error pages for when HA is down (or reloading), but that’s a minor todo.
The config:
/srv/hass/nginx/nginx.conf
worker_processes auto;
error_log /dev/stdout info;
pid /run/nginx.pid;
include /usr/share/nginx/modules/mod-stream.conf;
events {
worker_connections 1024;
http {
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
ssl_certificate "/run/secrets/smart.home.example.org.cert";
ssl_certificate_key "/run/secrets/smart.home.example.org.key";
server {
listen 8080;
listen [::]:8080;
server_name _;
return 301 https://$host$request_uri;
server {
listen 8443 ssl http2;
listen [::]:8443 ssl http2;
server_name smart.home.example.org;
ssl_session_cache shared:SSL:1m;
ssl_session_timeout 10m;
ssl_ciphers PROFILE=SYSTEM;
ssl_prefer_server_ciphers on;
proxy_buffering off;
location / {
proxy_pass http://10.0.2.2:8123;
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
And I’m using Red Hat’s UBI container with Nginx. This is the same binaries as Red Hat Enterprise Linux but free to use in containers with no strings attached. You could use whatever nginx container you like, really: it doesn’t matter much. But I like this because it has relatively long-term security commitments, making one less thing to worry about.
~/.config/systemd/user/container-nginx.service
[Unit]
Description=Nginx in a container to proxy to Home Assistant
Documentation=man:podman-generate-systemd(1)
Wants=container-certbot.service
After=container-certbot.service
[Service]
Environment=PODMAN_SYSTEMD_UNIT=%n TZ=US/Eastern
Restart=on-failure
RestartSec=30
TimeoutStopSec=10
--rm --sdnotify=conmon \
--replace \
--detatch \
--name nginx \
--net slirp4netns:allow_host_loopback=true \
-p 8080:8080 \
-p 8443:8443 \
--volume=/srv/hass/nginx/nginx.conf:/etc/nginx/nginx.conf:Z \
--secret smart.home.example.org.cert \
--secret smart.home.example.org.key \
registry.access.redhat.com/ubi8/nginx-120:latest nginx -g "daemon off;"
Type=notify
NotifyAccess=all
[Install]
Firewall config:
As noted above, this runs on ports 8443 and 8080. Then, the standard ports are packet-forwarded locally by the firewall. To set this up, run:
sudo firewall-cmd --add-forward-port=port=80:proto=tcp:toport=8080
sudo firewall-cmd --add-forward-port=port=443:proto=tcp:toport=443
sudo firewall-cmd --runtime-to-permanent
The Actual Home Assistant Container
The main event, right? Actually not a lot to say here. Note that it “Wants” the other containers for Z-Wave and Zigbee rather than “Requires”. That means it expects them to be there, but won’t shut down if not.
Important: this is set up to use a watchdog provided by GitHub - brianegge/home-assistant-sdnotify: systemd service for Home Assistant. This makes it so if Home Assistant fails in some weird way but does not exit, the container will restart. Until you’ve got that set up (or if you decide not to use it), see the note in the comments.
You’ll need to make /srv/hass/hass
before starting, but there doesn’t need to be anything there.
~/.config/systemd/user/container-homeassistant.service
[Unit]
Description=Home Assistant Container
Wants=container-zwave.service
Wants=container-zigbee.service
After=container-zwave.service
After=container-zigbee.service
[Service]
Environment=PODMAN_SYSTEMD_UNIT=%n TZ=US/Eastern WATCHDOG_USEC=5000000
Restart=on-failure
RestartSec=30
TimeoutStopSec=70
# note: this is using https://github.com/brianegge/home-assistant-sdnotify.
# If not using that, remove the `WatchdogSec` line and change
# `--sdnotify=container` to `--sdnotify=conmon`.
WatchdogSec=60
--rm \
--sdnotify=container \
--replace \
--detach \
--name=homeassistant \
--volume=/srv/hass/hass:/config:Z \
--network=host \
ghcr.io/home-assistant/home-assistant:stable
Type=notify
NotifyAccess=all
[Install]
A brief interlude for SELinux and permissions
The next two containers, for Z-Wave and Zigbee, need access to the USB tty devices to actually talk to their controllers. If you are using at least container-selinux-2.176.0
, there is a boolean container_use_devices
you can use to allow containers to access devices, but that’s broader than I’d really like. So, I set up a custom SELinux module which just allows containers to access USB serial devices. This is still more broad than I’d like (I really want to only allow each specific container to access the _specific_device) but this will do for now. Here’s what to do.
Start with this policy source file:
container-usbtty.te
module container-usbtty 1.0;
require {
type container_t;
type usbtty_device_t;
class chr_file { getattr ioctl lock open read write };
#============= container_t ==============
allow container_t usbtty_device_t:chr_file { getattr ioctl lock open read write };
and run:
checkmodule -M -m -o container-usbtty.mod container-usbtty.te
semodule_package -o container-usbtty.pp -m container-usbtty.mod
sudo semodule -i container-usbtty.pp
This will persist; you only need to do it once.
You’ll also need to add your container-user (hass
in this example) to the dialout
group, which will allow regular Unix-permission access to these devices:
will do it. (If you’re working as the hass
user, you’ll need to log out and in again to get the new supplementary group list).
The Z-Wave container
Note that despite the name, this doesn’t require MQTT. You can configure it, instead, to talk directly to Home Assistant, and that’s what I’ve done since it seems to be the generally-recommended approach.
The directory /srv/hass/zwave
needs to exist, but can be empty to start — when you run the service and connect to port 8123 in your web browser, you can configure everything from there.
This config maps the device identifier to /dev/zwave
. That way, the zwavejs2mqtt config doesn’t need a long complicated path. Something feels “itchy” to my sense of neatness in how a lot of important configuration is podman command-line parameters. I may look at making a shared wrapper things like device paths can be in a common config file.
~/.config/systemd/user/container-zwave.service
[Unit]
Description=ZWave To MQTT Container
[Service]
Restart=on-failure
RestartSec=30
TimeoutStopSec=70
--rm \
--sdnotify=conmon \
--replace \
--detach \
--name=zwave \
--group-add keep-groups \
--device=/dev/serial/by-id/usb-Silicon_Labs_Zooz_ZST10\u00A0700_Z-Wave_Stick_0001-if00-port0:/dev/zwave:rw \
--volume=/srv/hass/zwave:/usr/src/app/store:Z \
-p 8091:8091 \
-p 3000:3000 \
zwavejs/zwavejs2mqtt:latest
Type=notify
NotifyAccess=all
[Install]
MQTT Bridge (Mosquitto)
MQTT is a standard messaging protocol used by lots of things in IoT. I initially didn’t want to bother with it, but there’s currently a problem with Home Assistant’s built-in Zigbee support (“ZHA”), and several people suggested that zigbee2mqtt doesn’t have the same issue. So, have exhausted other ideas, I tried it and — that seems to be true. And, unlike the zwave program, zigbee2mqtt doesn’t have a direct way to communicate, so I ended up biting this bullet.
My configuration here is really simple. There’s a lot more I could and probably should do. I definitely want to set up SSL and username/password.
For this one, you need /srv/hass/mosquitto/confg
and /srv/hass/mosquitto/data
directories pre-created. You could also have /srv/hass/mosquitto/log
, but I’ve currently configured it to not log, on the theory that I’ve got plenty of logging on the other side.
In this case, you do need to create the config file before starting the service.
Note: I’m open to suggestions and help for how I should configure this better. Currently, I don’t have it listening on the websockets interface, which I might want to add so I can use a web console tool for debugging.
/srv/hass/mosquitto/config/mosquitto.conf
log_dest stdout
log_type none
allow_anonymous true
listener 1883
persistence true
persistence_location /mosquitto/data/
And the systemd service:
~/.config/systemd/user/container-mosquitto.service
[Unit]
Description=Mosquitto MTTS in a container
[Service]
Restart=on-failure
RestartSec=30
TimeoutStopSec=10
--rm \
--sdnotify=conmon \
--replace \
--detach \
--name mosquitto \
-p 1883:1883 \
--volume=/srv/hass/mosquitto/config:/mosquitto/config:Z \
--volume=/srv/hass/mosquitto/data:/mosquitto/data:Z \
--volume=/srv/hass/mosquitto/data:/mosquitto/log:Z \
eclipse-mosquitto
Type=notify
NotifyAccess=all
[Install]
The Zigbee container
This one needs its configuration file created before you start the service the first time. Important: I’m changing the web port to 8092 from the default 8080, because 8080 is used by my Nginx config. (It wouldn’t have to, but I’ve set it up already, so I went this way.) I picked the port one higher than the one zwavejs2mqtt uses. (Reminder: these are blocked from outside-the-server access by the firewall. I intend to eventually also put them behind the ngnix proxy, so all of these port numbers become obscure implementation details you don’t have to worry about later.)
Similar to the Z-Wave configuration, I’ve mapped the controlller to /dev/zigbee
inside the container, so you only need to worry about the actual device name from the outside.
I’m logging to both console and file here (the former then goes to journalctl), and I have log level set to debug
while I’m setting things up – I will probably reduce that to info
once I feel confident about everything.)
The mqtt server is reached on what is defined by default in podman as the local network for containers, which works because of --network=slirp4netns:allow_host_loopback=true
in the podman config below. I may work on setting that network in a more sophisticated way. Plus, also, there should be a way to refer to it by name rather than hard-coded IP, but that wasn’t working for me — another TODO!
/srv/hass/zigbee/configuration.yaml
homeassistant:
legacy_entity_attributes: false
legacy_triggers: false
frontend:
port: 8092
url: http://smart.home.example.org:8092
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://10.0.2.2
serial:
port: /dev/zigbee
advanced:
homeassistant_legacy_entity_attributes: false
legacy_api: false
log_level: debug
log_output:
- console
- file
device_options:
legacy: false
Once you’re running, zigbee2mqtt itself will add detected devices to this file. But the above is what you need to start.
and…
~/.config/systemd/user/container-zigbee.service
[Unit]
Description=Zigbee To MQTT Container
Requires=container-mosquitto.service
After=container-mosquitto.service
[Service]
Restart=on-failure
RestartSec=30
TimeoutStopSec=70
--rm \
--sdnotify=conmon \
--replace \
--detach \
--name=zigbee \
--network=slirp4netns:allow_host_loopback=true \
--device=/dev/serial/by-id/usb-1a86_TubesZB_971207DO-if00-port0:/dev/zigbee:rw \
--volume=/srv/hass/zigbee:/app/data:Z \
-p 8092:8092 \
koenkk/zigbee2mqtt:latest
Type=notify
NotifyAccess=all
[Install]
Backups
RIght now, they’re just covered by my desktop system backups. In the future, I’m going to set up something specific for this. You should just be able to back up all of /srv/hass
There is however one notable exception: if you want to avoid the possibility of backing up home-assistant_v2.db
when it’s in a not-settled state (possibly leading to corruption and losing your state history), you should periodically run something like
echo 'vacuum into "/src/hass/backup/home-assistant_v2-bak.db"' | sqlite3 /srv/hass/hass/home-assistant_v2.db
TODO
There are number of things I want to do yet. Notably:
- SSL for the zigbee and zwave web frontends (there are still a number of things more easily done directly than with the HA interface)
- SSL for mosquitto
- Redo my whole network with unique security keys for zwave and zigbee. Some rainy day.
- Collect all of this into a git repo and/or tar release which you can just clone or unpack to get started. And maybe even a setup script which takes it a step further, using your desired hostnames and proper device paths, setting up the systemd session properly, etc.
Other ideas:
- Containerized tools for zigbee and zwave controller firmware updates
- Create a wrapper for all the podman calls so the systemd files can be more boilerplate and the specifics of the setup in a general config file
- Move to an in-memory sqlite database for home-assistant, copying to disk only periodically. Trade performance for possbility of losing an hour (or whatever) of history
- figure out how to make HA do a clean shutdown when it gets a SIGTERM from podman (or use a different signal and configure for that?)
- podman auto-update rollback that is informed by tests run on startup, so that if there’s a breaking change it automatically reverts to known-good
Questions, Comments?
And that’s basically it. Let me know what’s unclear — and especially any suggestions for improvement.
