For detailed instruction on how to do this, look here: Home Assistant: Multiple Evohome Locations
The above is a first draft: please submit an Issue if that wiki has any problems with it.
Good luck.
Good luck.
@zxdavb I already have a custom _components folder housing several other custom integrations, you mention start with a clean set up, does this mean I need to make a second custom_components folder or can I just add the secondary instance of evohome in my existing folder?
@zxdavb I followed all the steps in your WIKI but still get the message "integration error: âevohome_1â - not found
The meaning was to remove all the existing evohome
folders from under custom_components
, if any.
The custom_components
folder, and any of the âotherâ folders under it - those containing other integrations - should remain unmolested.
I am sorry if the language was not clear.
You can simply add an evohome_1
folder to the custom_components
folder, but you must also delete any evohome*
folders left over from before.
Regarding the rest, I will check it tomorrow-ish, and get back to you.
In the meantime, could you provide more detail about your installation, and some specifics of how you achieved the instructions in the wiki.
Please include a copy of your configuration.yaml,
@zxdavb I did try to add to my existing custom_components folder following the steps you gave in WIKI using the SHH Terminal add-on also did try to add it by manually download the evohome Integration raw files and copy paste them in evohome_1 folder within custom_components trying with samba share from my PC and trying to add true file editor, all 3 of these ways to add the secondary integration result in the same error message that integration not can be found.
My primary evohome integration runs already for over 1,5 year without problems
Like this I tryed to add it to my configuration.yaml
evohome:
username: âprimary accountâ
password: â##########â
location_idx: â1â
evohome_1:
username: âgranted access accountâ
location_idx: â0â
And this is my system info running on a âhome assistant blueâ device:
version | core-2023.8.3 |
installation_type | Home Assistant OS |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.11.4 |
os_name | Linux |
os_version | 6.1.39 |
arch | aarch64 |
timezone | Europe/Bucharest |
config_dir | /config |
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 4996 |
Installed Version | 1.32.1 |
Stage | running |
Available Repositories | 1272 |
Downloaded Repositories | 27 |
can_reach_server | ok |
remaining_requests | 24 |
logged_in | true |
subscription_expiration | September 15, 2023 at 03:00 |
relayer_connected | true |
relayer_region | eu-central-1 |
remote_enabled | true |
remote_connected | true |
alexa_enabled | false |
google_enabled | true |
remote_server | eu-central-1-4.ui.nabu.casa |
certificate_status | ready |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 10.4 |
update_channel | stable |
supervisor_version | supervisor-2023.08.1 |
agent_version | 1.5.1 |
docker_version | 23.0.6 |
disk_total | 113.9 GB |
disk_used | 62.5 GB |
healthy | true |
supported | true |
board | odroid-n2 |
supervisor_api | ok |
version_api | ok |
installed_addons | Spotify Connect (0.12.4), Home Assistant Google Drive Backup (0.111.1), File editor (5.6.0), Advanced SSH & Web Terminal (15.0.7), Samba share (10.0.2), MariaDB (2.6.1), ESPHome (2023.8.1), Assistant Relay (0.7.4), Mosquitto broker (6.2.1), Zigbee2MQTT (1.32.2-1) |
dashboards | 1 |
resources | 16 |
views | 21 |
mode | storage |
oldest_recorder_run | August 9, 2023 at 08:45 |
current_recorder_run | August 19, 2023 at 00:21 |
estimated_db_size | 1640.14 MiB |
database_engine | mysql |
database_version | 10.6.12 |
version | 3.5.2 (2ad1cd7) |
cloud_online | 10 / 10 |
local_online | 10 / 10 |
api_endpoint_reachable | ok |
@sesame26 Thanks for the additional informationâŚ
I apologise: I believe English may not be your native language, and so if I have misunderstood you, please forgive meâŚ
First, I am only needing you to confirm that you followed the instructions in the Wiki exactly. If you added a command, or didnât execute a command, then do tell me.
I am not interested in using Samba, etc - this is not in the wiki article. Please limit yourself to the exact instructions of the wiki.
Please be precise. For example, use formatting when necessary.
re: the configuration.yaml, I think you meant:
evohome:
username: "primary account"
password: "##########"
location_idx: 1
evohome_1:
username: "granted access account"
location_idx: 0
Please use the secrets.yaml file as described in the wiki.
Please follow the wiki again, but only via the SSH add-on. I wonder if you have a problem with permissions (I am using a different SSH add-on), so - when youâve finished, try:
ls -al /config/custom_components/evohome_1
And post the results here.
@sesame26 I just had a lookâŚ
I have made a few mistakes in the instructions.
For now, I will remove this bit:
await asyncio.sleep(5)
⌠and the manifest.json is missing a comma:
"requirements": ["evohome-async==0.3.15"]
⌠it should have a trailing comma:
"requirements": ["evohome-async==0.3.15"],
So, I will edit the wiki, and post here when it is good for you to try again.
@sesame26 OK, try now. Good luck.
@zxdavb yes I did follow the WIKI exactly as you described everything in there
My configuration.yaml indeed looks like you posted BUT I have, username, password and idx_location values all between " " so I not use 1 as value for idx_location but â1â I have it like this also in original evohome config and it works for 1.5 year already.
I will tomorrow try again your adjusted WIKI and let you know if did succeed or not.
Thanks!
@zxdavb I did try add again and still have the same error that integration can not be found if i run the following line > ls -al /config/custom_components/evohome_1 > I get to see following on the picture I added below to this post
What did you get when you:
cat /config/custom_components/evohome_1/manifest.json
⌠and:
cat /config/custom_components/evohome_1/const.py | grep 'DOMAIN'
@zxdavb excactly the same as in the WIKI
âdomainâ: âevohome_1â,
ânameâ: âHoneywell Total Connect Comfort (Europe)â,
âcodeownersâ: ["@zxdavb"],
âdocumentationâ: âHoneywell Total Connect Comfort (Europe) - Home Assistantâ,
âiot_classâ: âcloud_pollingâ,
âloggersâ: [âevohomeasyncâ, âevohomeasync2â],
âversionâ: â0.0.1â,
ârequirementsâ: [âevohome-async==0.3.15â]
DOMAIN = âevohome_1â
STORAGE_KEY = DOMAIN
If you donât have the asyncio.sleep(5)
in __init__.py
, then I suggest you simply restart HA.
HA will still start, and the log file will include the reason why evohome_1
wasnât found.
Please use formatting - wrap text in three back-quotes, for example.
When you have restarted, try this:
cat /config/home-assistant.log | grep evohome
@zxdavb it will even restart if gives error in Developer Tools? I not get the âConfiguration will not prevent Home Assistant from starting!â message now, so honestly I find it a bit scary to still restart this way
It is your system, so up to you.
⌠but I have - as expected - just successfully restarted HA even with this error message:
The system cannot restart because the configuration is not valid: Integration error: evohome_x - Integration 'evohome_x' not found.
You restart as you describe, but select Advanced options at the bottom of the dialog box, then Reboot system, then Reboot.
When I correct my configuration.yaml (from evohome_x:
back to evohome_1:
), and corrupt my manifest,json, and restart HA again, in the error log, I executed:
⌠and got:
2023-08-19 21:54:13.035 ERROR (SyncWorker_0) [homeassistant.loader] Error parsing manifest.json file at /config/custom_components/evohome_1/manifest.json: trailing comma is not allowed: line 9 column 21 (char 328)
2023-08-19 21:54:34.279 ERROR (MainThread) [homeassistant.setup] Setup failed for evohome_1: Integration not found.
⌠all the other integrations started successfully.
Sorry:
To reboot, go to Settings, then three button menu on the top-right, then Restart Home Assistant, then select Advanced options at the bottom of the dialog box, then Reboot system , then REBOOT .
@zxdavb I did delete again all and then added manual with file editor
âversionâ: â0.0.1â,
âââSupport for (EMEA/EU-based) Honeywell TCC climate systems.â""
STORAGE_VER = 1
EVO_RESET = âAutoWithResetâ
EVO_AUTO = âAutoâ
EVO_AUTOECO = âAutoWithEcoâ
EVO_AWAY = âAwayâ
EVO_DAYOFF = âDayOffâ
EVO_CUSTOM = âCustomâ
EVO_HEATOFF = âHeatingOffâ
EVO_FOLLOW = âFollowScheduleâ # the operating mode is âinheritedâ from the TCS
EVO_TEMPOVER = âTemporaryOverrideâ
EVO_PERMOVER = âPermanentOverrideâ
GWS = âgatewaysâ
TCS = âtemperatureControlSystemsâ
UTC_OFFSET = âcurrentOffsetMinutesâ
then I did access my custom_components folder through SSH Terminal using following comand : cd ~/config/custom_components
after that I executed following comand to give executable rights to the files in evohome_1 folder : chmod +x evohome_1/*
then I restarted HA
then I added credentials to configuration.yaml
evohome:
location_idx: â1â
evohome_1:
location_idx: â0â
checked config in âDeveloper Toolsâ tools and I had no more error and got the âConfiguration will not prevent Home Assistant from starting!â message
After did do a other restart and all started up as expected and I have climate entities for my second location as well services added for the second location starting with evohome_1.xxxxxxxx
So finally I got it working!
Thank you for your help and efforts!
Well-done.
For those who follow, I recommend this process, instead of the above:
It offers several advantages over the process described above, and - if people raise an issue on the repo - I will keep the wiki up to date.
For those who want to have multiple evohome locations, this wiki has the solution.
evohome:
username: !secret TCC_USERNAME
password: !secret TCC_PASSWORD
location_idx: 0
evohome_1:
username: !secret TCC_USERNAME_1
password: !secret TCC_PASSWORD_1
location_idx: 1
It is the same wiki as the previous post, but has been updated to correct an issue.
If you have any difficulties with it, then submit an issue here.
