Workday integration config problem
I added the workday integration to my HA Core v.2025.1.1 setup. The integration is working, but now every time I go into the HA interface, I get a pop-up asking me to configure the workday integration. As far as I can tell, all the configuration options are completed. These constant pop-ups are very annoying
Can anybody suggest a way to fix this?
Well, usually there are five workdays, … :wink:
Kidding aside, just tried to add it. I need to specify a country, then the normal workdays and what to include or exclude. Then it is done and I do not get it again. Maybe if you remove it and add it again? Or is there something in the logs about errors that prevent the integration from loading correctly? What options did you pick?
The odd thing is that it’s working ok in my automation. I’ll try removing it and adding it back.
Well, removing the integration and putting it back seems to have fixed the problem. Thanks for the suggestion.
