Workday integration option for work from home and work outside. A lot of people work one or more days from home and therefore you need other automations or the same, but other times. It should be perfect when you can select with days you work from home and with days you work outside!
You can use a schedule helper or local calendar for this.
A schedule helper is a good alternative, but I think this should be perfect in the workday integration. The whole integration isn’t helpful when you also need to make a schedule helper.
