Workday sensor yaml formatting
Is this right? I added it to my configuration.yaml.
binary_sensor:
  - platform: workday
    country: US
    workdays: [mon, tues, wed, thu, fri]
I could not get his working, something about workdays: not supported, or something like that. I just wanted to make sure I had the proper formatting, it seemed pretty straightforward,
Looks right to me, but I’ve never tried this platform. If you could share the exact error message, that might help.
Thanks,
Sorry for posting without having the error message with me. :slight_smile:
I removed it and then left for the day. It was something about the workdays section. something about data @ ,
I’ll add it back this eveing and get the exact message.
typically lists are denoted as:
binary_sensor:
  - platform: workday
    country: US
    workdays:
      - mon
      - tues
      - wed
      - thu
      - fri
don’t know if thats what the platform wants though.
EDIT: the documentation has it your way @ptdalen
I believe lists can also be entered as [a, b, c]. In fact, that’s what the doc page for this platform shows.
I did try it that way as well. Same (or very similar) error.
Sorry, will post better info tonight.
#DownTimeAtWork?
Take the S off tues.
According to the docs the list accepts only 3 letter values for the days.
ha! Yes, I’m sure that’s it. Thanks for the second set of eyes
That was it, thanks!
у меня не работает:
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 34). Please check the docs at https://home-assistant.io/integrations/sensor/
your yaml spacing is wrong
binary_sensor:
  - platform: workday
    country: RU
where is the mistake?
Where is this code? In a file named sensors.yaml that is included like this:
sensor: !include sensors.yaml
Or something like that?
If so, then in effect you have this:
  binary_sensor:
    - platform: workday
      country: RU
which is incorrect.
the configuration.yaml says:
sensor: !include sensor.yaml
the sensor.yaml says:
# система
  - platform: time_date
    display_options:
     - 'time'
     - 'date'
  - platform: systemmonitor
    resources:
    - type: processor_use
    - type: memory_free
    - type: memory_use
      arg: /
  - platform: command_line
    command: "cat /sys/class/thermal/thermal_zone0/temp"
    unit_of_measurement: "°C"
    value_template: '{{ value | multiply(0.001) | round(1) }}'
# давление паскаль/рт.ст
    sensors:
      pressure_hg:
        friendly_name: "давление"
        unit_of_measurement: 'ммРс'
        value_template:
          "{{ (states('sensor.pressure_158d000411d3ed') | float /1.333) | round(0) }}"
# рабочая неделя
  - binary_sensor:
      - platform: workday
        country: RU
the other two are working fine.
work week swears
Workday is a binary sensor. That’s different to sensor.
Take it out of your sensors.yaml and add it directly to the configuration.yaml
Here’s my workday sensor, from sensors_binary.yaml as referenced in configuration.yaml:
binary_sensor: !include sensor_binary.yaml
- platform: workday
  country: US
  workdays: [mon, tue, wed, thu, fri]
  excludes: [sat, sun]
  add_holidays:
      - '2019-09-02'
      - '2019-11-28'
      - '2019-12-24'
      - '2019-12-25'
      - '2020-01-01'
      - '2020-05-25'
      - '2020-07-03'
      - '2020-09-07'
      - '2020-11-26'
      - '2020-12-25'
Yes, it works now.
removed from sensor.yaml, entered in configuration.yaml, now everything is fine.
thanks friends!
