Working Automation with Telegram Errors
As the topic states, I have an automation that once triggered sends a picture via telegram, the automation triggers, picture gets sent, but I notice the following error in the log repeated multiple times.
2018-03-07 12:01:05 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback SendfilePayloadWriter._sendfile_cb(<Future cancelled>, 47, 40, 856680, 1473296, <_UnixSelecto...e debug=False>, True)
  File "/usr/lib/python3.5/asyncio/events.py", line 126, in _run
    self._callback(*self._args)
  File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_fileresponse.py", line 38, in _sendfile_cb
    loop.remove_writer(out_fd)
  File "/usr/lib/python3.5/asyncio/selector_events.py", line 351, in remove_writer
    self._ensure_fd_no_transport(fd)
  File "/usr/lib/python3.5/asyncio/selector_events.py", line 258, in _ensure_fd_no_transport
    fd, transport))
RuntimeError: File descriptor 47 is used by transport <_SelectorSocketTransport fd=47 read=polling write=<polling, bufsize=0>>
Can anyone provide some insight?
Automation:
  - alias: Living Room Motion
    - platform: state
      to: 'on'
      entity_id: binary_sensor.living_room_sensor_motion
    - service: script.living_room
    - service: notify.telegram
        title: Living Room Alert!
        message: Someone is in the house.
          photo:
            - file: /home/homeassistant/.homeassistant/cameraimages/living_room.jpg
I also notice on the receiving side, there is no title or message, just the picture, is this normal behavior when sending photo?
90% sure action can only have 1 service. Could be the cause of the issue.
Well, I think the other 10% just out-ruled you, the both service run, and execute as expected, but could still be causing it to through the error.
Any idea how I can trouble shoot?
There is also examples in the docs that show the use of multiple service.
Automation Actions:
    # Actions are scripts so can also be a list of actions
    - service: notify.notify
        message: Beautiful sunset!
    - delay: 0:35
        message: Oh wow you really missed something great.
Have you tried using debug for the logger? This error could be unrelated to your automation.
Good to know, I’ve always wanted to do that but created a script for it. I don’t know why that isn’t covered under the normal automation section… Seems like the docs are too segmented.
It’s ironic, I rebooted just after my initial post and the error hasn’t showed up since, but i have seen the same error some time ago prior to this, I will debug and report back.
Thanks.
Automation just ran and was succesfull, but got the following error:
2018-03-07 14:46:06 ERROR (Thread-11) [homeassistant.components.telegram_bot] Error sending file: Timed out. Args: (390135429, <_io.BufferedReader name='/home/homeassistant/.homeassistant/cameraimages/living_room.jpg'>), kwargs: {'parse_mode': 'Markdown', 'reply_markup': None, 'disable_notification': False, 'timeout': None, 'caption': None, 'reply_to_message_id': None, 'disable_web_page_preview': None}
Still strugling to resolve the Telegram errors, error is created when any automation using Telegram is triggered.
Anyone have any idea how I can diagnose this error, or what needs to be changed/added?
2018-04-16 22:17:48 ERROR (Thread-10) [homeassistant.components.telegram_bot] Error sending message: Invalid server response. Args: (390135429, 'Pi3 CPU temperature is currently 128.6°!'), kwargs: {'parse_mode': 'Markdown', 'timeout': None, 'reply_markup': None, 'disable_notification': False, 'reply_to_message_id': None, 'disable_web_page_preview': None}
So i must have missed your response a month ago.
Looks like its a bug in the telegram component. This is basically saying that the response from telegram is crap. There may be nothing you can do.
For some reason, the component doesn’t like the arguments or keyword arguments. The component must be looking for a specific number of arguments or a specific keyword argument that is missing.
You’re only options are to debug the component and find out why it doesn’t like the arguments or keyword arguments.
@petro Thank you for following up.
After commenting, I did some reading on your post’s and recomendation’s, and ended up adding parse_mode: html which seems to be keeping it quite for the moment, will update on any changes.
Thanks.
telegram_bot:
  - platform: polling
    api_key: !secret telegram_api_key
    allowed_chat_ids:
      - !secret telegram_chat_id
    parse_mode: html
Hmm, maybe it was returning a string instead of the actual objects needed. I did find it odd that ā€˜Args’ was capitalized. This leads me to believe that they printed a string and assumed it was a sentence and capitalized the first letter of the string. This is all conjecture though.
I was thinking it was expecting more unspecified info which i should provide, but didn’t know how.
I was also getting 502 errrors.
Talked too soon.
Still getting error’s when sending image:
2018-04-17 10:40:53 ERROR (Thread-10) [homeassistant.components.telegram_bot] Error sending file: Timed out. Args: (390135429, <_io.BufferedReader name='/home/homeassistant/.homeassistant/cameraimages/frontdoor.jpg'>), kwargs: {'parse_mode': 'HTML', 'reply_to_message_id': None, 'reply_markup': None, 'timeout': None, 'disable_web_page_preview': None, 'disable_notification': False, 'caption': None}
That’s a different error. That could be a connection issue.
Connection to the Bot?
Error looks similar, but for a different Automation.
The confusing part is that the message is sent and received with the image.
Well, the meat of the errors is here:
and here:
I found the second error in the source file. Are you getting a debug message ā€œLast message ID: ā€¦ā€ before any these errors?
or ā€œUpdate last message: ā€¦ā€
I will set to debug and re-run automations
It’s probably not worth it. I debugged down all the way to the errors and their meaning and both point to connection issues. Both errors inherit from NetworkError.
To what/where?
To the telegram bot I’m guessing. I have no idea what this device is. If its internal to your network, then you are having network issues. If its external from your network, then it’s having trouble sending or receiving a ā€˜confirmation’ from the send.
I just looked it up, its a cloud based service. So most likely, your network isn’t routing the telegram bot responses back to HA properly. This may be caused by your router/network configuration.
