Working ESPHome config for ttgo ESP32 camera board with microphone
Sooo… anyone ever got the Microphone to work?
V1.6.2 with Mic is supposed to have SCK26 WS32 SDO33
i tried with this yaml:
esphome:
  friendly_name: Camera-ESP
esp32:
  board: esp32dev
  framework:
    type: arduino
i2c:
  sda: GPIO21
  scl: GPIO22
i2s_audio:
  i2s_lrclk_pin: GPIO32
  i2s_bclk_pin: GPIO26
microphone:
  - platform: i2s_audio
    i2s_din_pin: GPIO33
    adc_type: external
    pdm: false
voice_assistant:
  microphone: adc_mic
time:
  - platform: homeassistant
binary_sensor:
  - platform: gpio
    pin: GPIO19
    device_class: motion
  - platform: gpio
    pin:
      number: GPIO15
      mode: INPUT_PULLUP
      inverted: True
  - platform: wifi_signal
    name: "ttgocam2 WiFi Signal"
    update_interval: 60s
font:
  - file: "fonts/times-new-roman.ttf"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.strftime(64, 0, id(tnr1), TextAlign::TOP_CENTER,"%d-%m-%Y", id(homeassistant_time).now());
      it.strftime(64, 64, id(tnr2), TextAlign::BASELINE_CENTER, "%H:%M", id(homeassistant_time).now());
esp32_camera:
  external_clock:
    pin: GPIO4
    frequency: 20MHz
  i2c_pins:
    sda: GPIO18
    scl: GPIO23
  data_pins: [GPIO34, GPIO13, GPIO14, GPIO35, GPIO39, GPIO38, GPIO37, GPIO36]
  vsync_pin: GPIO5
  href_pin: GPIO27
  pixel_clock_pin: GPIO25
  jpeg_quality: 10
  vertical_flip: true
  horizontal_mirror: false
  # Image settings
# Enable logging
logger:
but i don’t know how to integrate that into HA now… or if it even works?
The Bootlog from the ESP32 doesn’t mention audio or microphone anywhere…
[03:29:01][I][app:102]: ESPHome version 2023.11.6 compiled on Dec  6 2023, 03:28:16
[03:29:01][C][wifi:559]: WiFi:
[03:29:01][C][wifi:391]:   Local [redacted]
[03:29:01][C][wifi:396]:   SSID: [redacted]
[03:29:01][C][wifi:397]:   IP Address: 192.168.1.236
[03:29:01][C][wifi:399]:   BSSID: [redacted]
[03:29:01][C][wifi:400]:   Hostname: 'esphome-web-454f70'
[03:29:01][C][wifi:402]:   Signal strength: -56 dB ▂▄▆█
[03:29:01][C][wifi:406]:   Channel: 12
[03:29:01][C][wifi:407]:   Subnet: 255.255.255.0
[03:29:01][C][wifi:408]:   Gateway: 192.168.1.1
[03:29:01][C][wifi:409]:   DNS1: 192.168.1.1
[03:29:01][C][wifi:410]:   DNS2: 0.0.0.0
[03:29:01][C][logger:416]: Logger:
[03:29:01][C][logger:417]:   Level: DEBUG
[03:29:01][C][logger:418]:   Log Baud Rate: 115200
[03:29:01][C][logger:420]:   Hardware UART: UART0
[03:29:01][C][i2c.arduino:053]: I2C Bus:
[03:29:01][C][i2c.arduino:054]:   SDA Pin: GPIO21
[03:29:01][C][i2c.arduino:055]:   SCL Pin: GPIO22
[03:29:01][C][i2c.arduino:056]:   Frequency: 50000 Hz
[03:29:01][C][i2c.arduino:059]:   Recovery: bus successfully recovered
[03:29:01][I][i2c.arduino:069]: Results from i2c bus scan:
[03:29:01][I][i2c.arduino:075]: Found i2c device at address 0x3C
[03:29:01][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'ttgocam2 PIR'
[03:29:01][C][gpio.binary_sensor:015]:   Device Class: 'motion'
[03:29:01][C][gpio.binary_sensor:016]:   Pin: GPIO19
[03:29:01][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'ttgocam2 Button'
[03:29:01][C][gpio.binary_sensor:016]:   Pin: GPIO0
[03:29:01][D][api:102]: Accepted 192.168.1.1
[03:29:01][C][homeassistant.time:010]: Home Assistant Time:
[03:29:01][C][homeassistant.time:011]:   Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[03:29:01][C][esp32_camera:048]: ESP32 Camera:
[03:29:01][C][esp32_camera:049]:   Name: My Camera
[03:29:01][C][esp32_camera:050]:   Internal: NO
[03:29:01][C][esp32_camera:052]:   Data Pins: D0:34 D1:13 D2:14 D3:35 D4:39 D5:38 D6:37 D7:36
[03:29:01][C][esp32_camera:053]:   VSYNC Pin: 5
[03:29:01][C][esp32_camera:054]:   HREF Pin: 27
[03:29:01][C][esp32_camera:055]:   Pixel Clock Pin: 25
[03:29:01][C][esp32_camera:056]:   External Clock: Pin:4 Frequency:20000000
[03:29:01][C][esp32_camera:060]:   I2C Pins: SDA:18 SCL:23
[03:29:01][C][esp32_camera:062]:   Reset Pin: -1
[03:29:01][C][esp32_camera:080]:   Resolution: 640x480 (VGA)
[03:29:01][C][esp32_camera:129]:   JPEG Quality: 10
[03:29:01][C][esp32_camera:131]:   Contrast: 0
[03:29:01][C][esp32_camera:132]:   Brightness: 0
[03:29:01][C][esp32_camera:133]:   Saturation: 0
[03:29:01][C][esp32_camera:134]:   Vertical Flip: ON
[03:29:01][C][esp32_camera:135]:   Horizontal Mirror: OFF
[03:29:01][C][esp32_camera:136]:   Special Effect: 0
[03:29:01][C][esp32_camera:137]:   White Balance Mode: 0
[03:29:01][C][esp32_camera:140]:   Auto Exposure Control: 1
[03:29:01][C][esp32_camera:141]:   Auto Exposure Control 2: 0
[03:29:01][C][esp32_camera:142]:   Auto Exposure Level: 0
[03:29:01][C][esp32_camera:143]:   Auto Exposure Value: 300
[03:29:01][C][esp32_camera:144]:   AGC: 1
[03:29:01][C][esp32_camera:145]:   AGC Gain: 0
[03:29:01][C][esp32_camera:146]:   Gain Ceiling: 0
[03:29:01][C][esp32_camera:152]:   Test Pattern: NO
[03:29:01][D][api.connection:1089]: Home Assistant 2023.11.3 (192.168.1.1): Connected successfully
[03:29:01][C][psram:020]: PSRAM:
[03:29:01][C][psram:021]:   Available: YES
[03:29:01][C][psram:024]:   Size: 4095 KB
[03:29:01][D][time:045]: Synchronized time: 2023-12-06 03:29:01
[03:29:01][C][ssd1306_i2c:023]: I2C SSD1306
[03:29:01][C][ssd1306_i2c:023]:   Rotations: 0 °
[03:29:01][C][ssd1306_i2c:023]:   Dimensions: 128px x 64px
[03:29:01][C][ssd1306_i2c:024]:   Address: 0x3C
[03:29:01][C][ssd1306_i2c:025]:   Model: SSD1306 128x64
[03:29:01][C][ssd1306_i2c:027]:   External VCC: NO
[03:29:01][C][ssd1306_i2c:028]:   Flip X: YES
[03:29:01][C][ssd1306_i2c:029]:   Flip Y: YES
[03:29:01][C][ssd1306_i2c:030]:   Offset X: 0
[03:29:01][C][ssd1306_i2c:031]:   Offset Y: 0
[03:29:01][C][ssd1306_i2c:032]:   Inverted Color: NO
[03:29:01][C][ssd1306_i2c:033]:   Update Interval: 1.0s
[03:29:01][C][captive_portal:088]: Captive Portal:
[03:29:01][C][mdns:115]: mDNS:
[03:29:01][C][mdns:116]:   Hostname: esphome-web-454f70
[03:29:01][C][ota:097]: Over-The-Air Updates:
[03:29:01][C][ota:098]:   Address: esphome-web-454f70.local:3232
[03:29:01][C][api:139]: API Server:
[03:29:01][C][api:140]:   Address: esphome-web-454f70.local:6053
[03:29:01][C][api:142]:   Using noise encryption: YES
[03:29:02][W][component:214]: Component ssd1306_base took a long time for an operation (0.27 s).
[03:29:02][W][component:215]: Components should block for at most 20-30ms.
[03:29:02][C][wifi_signal.sensor:009]: WiFi Signal 'ttgocam2 WiFi Signal'
[03:29:02][C][wifi_signal.sensor:009]:   Device Class: 'signal_strength'
[03:29:02][C][wifi_signal.sensor:009]:   State Class: 'measurement'
[03:29:02][C][wifi_signal.sensor:009]:   Unit of Measurement: 'dBm'
[03:29:02][C][wifi_signal.sensor:009]:   Accuracy Decimals: 0
[03:29:03][W][component:214]: Component ssd1306_base took a long time for an operation (0.26 s).
[03:29:03][W][component:215]: Components should block for at most 20-30ms.
i do see 7 devices.
Should the assist Pipeline simply get all the mic input? how would one check?
Or is my config not giving any output?
Is there a way to stream Mic Input to browser playback or such?
Okay… i got a little closer…
using Push to Talk function:
[04:04:48][D][binary_sensor:036]: 'ttgocam2 Button': Sending state ON
[04:04:48][D][voice_assistant:422]: State changed from IDLE to START_PIPELINE
[04:04:48][D][voice_assistant:428]: Desired state set to START_MICROPHONE
[04:04:48][D][voice_assistant:124]: microphone not running
[04:04:48][D][voice_assistant:206]: Requesting start...
[04:04:48][D][voice_assistant:422]: State changed from START_PIPELINE to STARTING_PIPELINE
[04:04:48][D][voice_assistant:443]: Client started, streaming microphone
[04:04:48][D][voice_assistant:422]: State changed from STARTING_PIPELINE to START_MICROPHONE
[04:04:48][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[04:04:48][D][voice_assistant:159]: Starting Microphone
[04:04:48][D][voice_assistant:422]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[04:04:48][D][esp-idf:000]: E (107291) I2S: i2s_dma_intr_init(538): Register I2S Interrupt error
[04:04:48][D][esp-idf:000]: E (107303) I2S: i2s_driver_install(1950): I2S interrupt initailze failed
WARNING esphome-web-454f70: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for esphome-web-454f70
WARNING Disconnected from API
INFO Successfully connected to esphome-web-454f70 in 0.004s
seems like the microphone is NOT running.
Edit:
This Guy seem to have same issue:
And this guy seems to have found the Solution to this Problem:
