bg1000
(BobG)
July 13, 2019, 7:39pm
1
I recently purchased the version of the ttgo camera with the microphone and have been able to get it working in Home Assistant with ESPHome. The configuration is different than other versions of the board so I am posting this for others that might be interested. I am not (yet) doing anything with the microphone itself but the camera, button, PIR sensor, and display all work. You should note the following:
I purchased this item on Aliexpress - https://www.aliexpress.com/item/32968767440.html?spm=a2g0s.9042311.0.0.3da24c4dkWWbwq - I purchased the “color” with the microphone and the fish eye lens.
The seller’s documentation shows the wrong GPIO pins for the button and PIR sensor. I have sent them a message about this.
This gist which I learned about from a Dr. ZZZs video was very helpful. It doesn’t actually work but it provides a pretty good outline of how to setup one of these boards. - https://gist.github.com/Snipercaine/d8345571563536e9661422c3509d1119
This github repo shows the correct pinout and has a working ESPHome config for the camera section - https://github.com/lewisxhe/esp32-camera-series
The order that you list the data pins for the camera does matter. I originally listed them in the order listed on Aliexpress image which is exactly backwards from the config that actually works.
I made a handful of other changes, some were required to get it to work and some were personal preferences. I’m happy to answer questions.
substitutions:
devicename: ttgocam
friendly_name: Doorbell
ip_address: 192.168.2.251
esphome:
platform: ESP32
#board: esp-wrover-kit
board: esp32dev
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: $ip_address
gateway: 192.168.2.1
subnet: 255.255.255.0
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
binary_sensor:
- platform: gpio
pin:
number: GPIO19
mode: INPUT
inverted: False
device_class: motion
filters:
- delayed_off: 1s
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
filters:
- delayed_off: 50ms
- platform: status
- platform: wifi_signal
name: $friendly_name WiFi Signal
update_interval: 10s
- platform: uptime
esp32_camera:
external_clock:
pin: GPIO4
frequency: 20MHz
i2c_pins:
sda: GPIO18
scl: GPIO23
data_pins: [GPIO34, GPIO13, GPIO14, GPIO35, GPIO39, GPIO12, GPIO15, GPIO36]
vsync_pin: GPIO5
href_pin: GPIO27
pixel_clock_pin: GPIO25
# power_down_pin: GPIO26
resolution: 640x480
jpeg_quality: 10
vertical_flip: true
horizontal_mirror: false
i2c:
sda: GPIO21
scl: GPIO22
font:
- file: "fonts/times-new-roman.ttf"
time:
- platform: homeassistant
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
rotation: 180
lambda: |-
it.strftime(64, 0, id(tnr1), TextAlign::TOP_CENTER,"%m-%d-%Y", id(homeassistant_time).now());
it.strftime(64, 64, id(tnr2), TextAlign::BASELINE_CENTER, "%I:%M:%S%p", id(homeassistant_time).now());
rdehuyss
(Ronald Dehuysser)
July 13, 2019, 9:12pm
2
Are you able to use the microphone and play the sound on your PC speakers for example?
If so, would be a good component for a doorbell.
bg1000
(BobG)
July 14, 2019, 5:16pm
3
So the website shows 3 pins for the microphone, SCK, WS, SDO. Based on this I think it’s a digital microphone that uses I2S. I don’t see a component for this in ESPHome so I don’t think it’s currently supported. There are examples of this for arduino/ESPs online so it can, of course, be added by using existing libraries and modifying these examples. This is “on my todo list” but to be honest it’s a pretty long list so we’ll see if I get to it before someone else does.
I have quite a few ESP based DYI “things” I’ve built now and I really feel like I need to take the packaging to the next level and make things look more professional. It seems I am going to have to tackle 3D printing before I worry about microphone support.
bg1000
(BobG)
July 14, 2019, 5:19pm
4
I realized after posting this that the camera image is flipped horizontally. This config fixes that:
substitutions:
devicename: ttgocam
esphome:
platform: ESP32
board: esp32dev
wifi:
manual_ip:
# Enable logging
logger:
api:
ota:
binary_sensor:
- platform: gpio
pin:
number: GPIO19
mode: INPUT
inverted: False
filters:
- delayed_off: 1s
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
filters:
- delayed_off: 50ms
- platform: status
- platform: uptime
esp32_camera:
external_clock:
pin: GPIO4
frequency: 20MHz
i2c_pins:
sda: GPIO18
scl: GPIO23
vsync_pin: GPIO5
href_pin: GPIO27
resolution: 640x480
jpeg_quality: 10
vertical_flip: true
horizontal_mirror: true
i2c:
sda: GPIO21
scl: GPIO22
font:
time:
display:
address: 0x3C
rotation: 180
lambda: |-
esbenr
(Esben BĂĽcking-Rasmussen)
April 8, 2020, 9:43pm
5
bg1000:
file: “fonts/times-new-roman.ttf”
Hi. Thank you for posting this.
It’s working great.
Where do I put the font file, to make the configuration compile?
Kind regards,
Esben
bg1000
(BobG)
April 9, 2020, 9:28am
6
It’s been quite a while since I set this up . . . I just took a look and I see two copies of the file. One is in the same directory as the yaml file and the other is in a /fonts subdirectory. I’m not sure which one is correct.
dturgel
(Daniel Turgel)
June 23, 2020, 12:19am
7
BobG, do you have any ideas for getting the microphone to work? I was thinking of scouring github for some python packages that may work and contacting the manufacturer. Any other ideas?
bg1000
(BobG)
June 24, 2020, 12:57am
8
I haven’t looked into this. My initial thoughts would be to find a c++ example of using a microphone on an esp32 board and incorporating that into an ESPHome custom sensor.
dturgel
(Daniel Turgel)
June 25, 2020, 2:55am
9
BobG, good idea. Let me see if I can find that - will get back to you asap.
floatev
(Floatev)
October 3, 2020, 6:48pm
10
Thanks for sharing. My TTGO-Cam (purchased in July 2020 from aliexpress) has a different pin allowcation. I’ve posted my conifg below, hope it saves somebody some time.
substitutions:
friendly_name: Doorbell ESP
esphome:
platform: ESP32
wifi:
ssid: "urssid"
password: "urpaswrd"
ap:
ssid: "Doorbellcam Fallback Hotspot"
password: "urfbpaswrd"
captive_portal:
# Enable logging
logger:
api:
ota:
binary_sensor:
- platform: gpio
pin:
number: GPIO19
mode: INPUT
inverted: False
filters:
- delayed_off: 1s
- platform: gpio
pin:
number: GPIO15
mode: INPUT_PULLUP
inverted: True
filters:
- delayed_off: 50ms
- platform: status
- platform: uptime
esp32_camera:
external_clock:
pin: GPIO4
frequency: 20MHz
i2c_pins:
sda: GPIO18
scl: GPIO23
data_pins: [GPIO34, GPIO13, GPIO14, GPIO35, GPIO39, GPIO38, GPIO37, GPIO36]
vsync_pin: GPIO5
href_pin: GPIO27
resolution: 640x480
jpeg_quality: 10
vertical_flip: true
i2c:
sda: GPIO21
scl: GPIO22
font:
time:
display:
address: 0x3C
rotation: 180
lambda: |-
Dorko
(Dor Konviser)
October 8, 2020, 3:42pm
11
floatev:
esp32_camera:
external_clock:
pin: GPIO4
frequency: 20MHz
i2c_pins:
sda: GPIO18
scl: GPIO23
vsync_pin: GPIO5
href_pin: GPIO27
resolution: 640x480
jpeg_quality: 10
vertical_flip: true
i2c:
sda: GPIO21
scl: GPIO22
Thanks for sharing and help!
Thanks for your help!
I had your same configuration but also needed to modify main.cpp code for it to work as specified on another thread .
Just in case anyone else happens to have the same issue.
Bombei
(Ariel Elbaum)
January 20, 2021, 5:16am
13
Hey Dturgel, were you ever able to get the microphone working please?
snizzleorg
(Snizzleorg)
February 15, 2021, 2:55pm
14
Hi I have problems getting the camera to work. Apparently I have a V1.6.2 version of the board. If I compile the sketch without the camera part everything works nicely. However If I add
esp32_camera:
external_clock:
pin: GPIO4
frequency: 20MHz
i2c_pins:
sda: GPIO18
scl: GPIO23
vsync_pin: GPIO5
href_pin: GPIO27
jpeg_quality: 10
vertical_flip: true
I cannot even connect to the board anymore via wifi. Although OTA works.
Mikrofarad
(Ulrich Fischer)
March 20, 2021, 3:15pm
15
The problem seems to be the missing pullup for GPIO14.
Therefore I added these lines:
binary_sensor:
- platform: gpio
internal: true # sensor will not be exposed to Home Assistant
pin:
number: GPIO14
mode: INPUT_PULLUP
Good luck
Instead of name: and internal: you can simply use id: DummyIO14 and the sensor will also not be exposed to Home Assistant.
RT1080
(Ronald)
April 29, 2021, 9:06am
16
Thanks! this is great - no more errors. I managed to get the board live without this addition once and have been struggling to get it to work for a week. Was prepared to bin it thinking I bricked it. @Mikrofarad - one question though, is it normal that the dummy sensor updates its status continuously? Any way to reduce the frequency?
@PaulAntonDeen fyi
Mikrofarad
(Ulrich Fischer)
April 29, 2021, 12:39pm
17
Sorry, I don’t know any solution. What I did is changing the logging level:
logger:
level: Error # During development set it to Debug
You can use a filter:
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
filters:
- delayed_on: 1000ms
automic
(Pi)
April 19, 2023, 6:01pm
19
Hi All, I have the same or similar TTGO-Camera, and just got it working with the help from your above comments - thanks lots all <3
Mine is on version 1.7 though, and totally different GPIO pin config. Please see my config below for reference in case it helps anyone else <3
(I’ve hashed out secrets and changed name, ip addr, and printing text for security reasons)
esphome:
substitutions:
friendly_name: MF01
esp32:
board: esp32dev
Enable logging
logger:
api:
encryption:
key: “whatevers”
ota:
password: “whatevers”
wifi:
manual_ip:
static_ip: 10.10.10.2
gateway: 10.10.10.1
binary_sensor:
platform: gpio
pin:
number: GPIO33
mode: INPUT
inverted: False
filters:
platform: gpio
pin:
number: GPIO34
#mode: INPUT_PULLUP
mode: INPUT
inverted: True
filters:
platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
filters:
platform: status
platform: uptime
esp32_camera:
external_clock:
pin: GPIO32
frequency: 20MHz
i2c_pins:
sda: GPIO13
scl: GPIO12
data_pins: [GPIO5, GPIO14, GPIO4, GPIO15, GPIO18, GPIO23, GPIO36, GPIO39]
vsync_pin: GPIO27
href_pin: GPIO25
pixel_clock_pin: GPIO19
resolution: 640x480
jpeg_quality: 10
vertical_flip: true
i2c:
sda: GPIO21
scl: GPIO22
font:
time:
display:
model: “SSD1306 128x64”
address: 0x3C
rotation: 180
lambda: |-
it.strftime(64, 0, id(tnr1), TextAlign::TOP_CENTER,“My House”, id(homeassistant_time).now());
it.strftime(64, 32, id(tnr2), TextAlign::CENTER,“Go Away!”, id(homeassistant_time).now());
it.strftime(64, 64, id(tnr1), TextAlign::BASELINE_CENTER, “%H:%M:%S”, id(homeassistant_time).now());
automic
(Pi)
April 19, 2023, 6:03pm
20
ok, apologies for the above, the formatting got ruined by this site X-)
you’ll just need to look at the original posts and apply my GPIO pin changes (there’s a lot of them, as basically they nearly all change!) Hope this helps <3
