Hello everyone, i’m trying to add on a my first HA installation the hisense AC with AEH-W4A1 module.
I have done all installation as instruction (MQTT and Deiger addon), but now the resut is:
What i can recheck or verify?
Best regards
Best regards
Are there any automations available that use this integration?
For example: put the airco in night modus?
Dose someone remove wifi adapter and use raw rs485 protocol ?
interesting too
Hi everyone,
I have an Hisense Air Conditioner with AEH-W4E1 wi-fi module.
Everything worked correctly for a few months until a week ago the air conditioner became unavailable with this error:
D0827 15:38:02.102 selector_events.py:58] Using selector: EpollSelector
File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/app/aircon/__main__.py", line 304, in <module>
asyncio.run(run(parsed_args))
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 587, in run_until_complete
return future.result()
File "/app/aircon/__main__.py", line 169, in run
device = Device.create(config, notifier.notify)
File "/app/aircon/aircon.py", line 68, in create
model = config['model']
KeyError: 'model'
So I removed the config_[ac_name].json with the entire Hisense folder, then reinstalled AirCon and now when I configure it I have this error:
E0915 19:14:00.916 discovery.py:43] Failed to login to Hisense server:
Status 401: 'Unauthorized'
MQTT and Hisense account credentials are right. I tried to change the app code - it should be hisense-eu cause I use HiSmart Life app - but no success. I tried to create a new account on HiSmart Life app, but no success. What can I do?
Same error here.
Had it working a while ago. It wasn’t perfect. But it worked (sometimes)
Now I cannot get the airco’s installed. Did everything as described.
All the AC units get recognised, with all the attributes. But the status remains “unavailable”
I use this:
Hi there, is there a way to make it work with the new app as it uses the same 2.4 mhz network protocol. Regarding the configuration “GitHub - deiger/AirCon: Scripts for controlling Air Conditioners, e.g. with HiSense modules.” I have managed to configure it in HA the only thing I am challenging with is this error?
In the Integration HiSense Air Conditioners “E1022 12:55:24.811 discovery.py:71] No device is configured! Please configure a device first.”
Here is my config;
log_level: INFO
mqtt_host: localhost
mqtt_user: “null”
mqtt_pass: “null”
port: 8888
app:
I have a use different login methods with mqtt_user and pasword with credentals and “null” same result.
I cant find any solution on the error what so ever.
I have followed discussions regarding this topic. with still no luck.
Any help will be appreciated.
Can you elaborate a bit on the wiring and components used? I have 3 of these units, and will be trying this.
Great Job Silvio
have you some detail about project (hardware, wire connection, etc)
did you manage to solve the problem with the AEH-W4A1 not connecting? For me, after every reboot of HA, the integration stops working.
Hi!
Does anyone have experience integrating the AEH-W4G1?
For myself, I decided to integrate the air conditioner through IR ESPHOME. While I suffer.
Hey @silviop , that’s really cool. Could you please share some details about this project? more specifically the hardware and wiring?
guys, anyone had any success with the AEH-W4GX?
Hello Silvio. Can you share informations about hardware and software to use this solution? My hisense is new, with AEH-W4G2 module and at this time no integration work.
Thank you!
Scusa Davide, mica sei di Frattamaggiore?
No, nord Italia
I use the AEH-W4A1 module. Control and status is functional but unstable. Often the module disconnects from wifi regularly every 2 minutes. Regularly every 5 minutes I am unavailable in HA. I have already replaced the module with the new problem is the same. I assume that the problem is with the program in the module. Please advise me. Is there a possibility for it to work well
