i’ve created some timers on my irrigations valve.
I don’t know why, but it seems the timers doesn’t work as it should.
When triggered, timer entity change its status in Active but remaining attribute doesn’t start count-down.
You will not see the remaining attribute change in the Developer Tools/STATES ui. But the timer is running and if you display the timer in your HA ui you will see it counting down.
You need to display the remaining attribute. The state just says active. You will see it if you are able to open the more-info dialog for example but displaying the remaining attribute will also show it.
I don’t think this will work because even though the attribute ‘remaining’ is changing the state of the ‘timer’ (active) is not and therefore the xxxx_time_left template sensor you constructed will not update. To see that the timer is actually working go to Developer Tools/STATES and click on the circle-i icon next to the timer entity. A more-info box will open showing the remaining time counting down. To get this to work like you want will likely require custom coding.
You will likely get only two updates. Once at the start and once at the end as the timer transitions between idle and active states. Also if you pause it you will likely see an update too.
