Worx Landroid Package (Deprecated)
Refresh browser, clear cache
Hello, I have a small problem it doesn’t work for me and I did everything as per the instructions the entities don’t work either here is an excerpt from the config and general things like changing the name from mower to Karl here is an excerpt from it
Hi
I installed the integration and it works almost perfectly.
I also use the original Worx android app.
If I update anything in the app, it will also refresh in the HA (e.g. raindelay)
However,”multizone” is not. If I configure the multizone in HA, it will update in the app. But if I do this in the app, HA is still show the old value.
Is this how it should work?
One more question: Is a rain delay countdown number available?
Hello.
Your card is awesome.
Do you have the files for the rear wing and the support for the name?
Thank you.
No :wink: It’s a bug in the integration which I’m working on right now.
Only newer models have this feature, and will be available in an upcoming release.
By the way - Version 2 sneak-peak :wink:
So @Barmalej will have some work cut out when it’s ready for release :smiley:
Still some kinks to iron out before release thou, so no ETA yet
Hi All
has anyone used the data from Worx Landroid Package & home assistant and added it to apple HomeKit just interested if anyone has done this and how does it work
hi I would like the same but line 152 is not as above has the file changed its mdi:pause
and 154 is mdi:play
thanks in advance great add-on for home assistant
Hallo
I had the whole thing running before. Unfortunately, I was forced to import a backup. Now I can no longer get a login to the landroid cloud. I have already deleted the mower from the app and added it again. I’ve already deleted everything and have only installed landroid-cloud at the moment. No connection possible. when starting homeassistant, a configuration error appears immediately. Cache has also been taught several times. TCP port 8883 opened. but went without before.
Does somebody has any idea
Setup failed for custom integration landroid_cloud: Integration failed to initialize.
15:56:40 – (FEHLER) setup.py
Error in authentication!
15:56:40 – (WARNUNG) landroid_cloud (benutzerdefinierte Integration)
Can you login with your credentials here?
Yes i can do. Also App works
Do you have these entries in configuration.yaml
landroid_cloud:
  - email: [email protected]
    password: YourPassword
Yes i have it
My Sytem is
Home Assistant Core 2022.5.5
Home Assistant Supervisor 2022.05.3
Home Assistant OS 8.1
Kernel version 5.15.32-v8
Agent version 1.2.1
On a pi 4 with a ssd
Remove it either from configuration.yaml or from landroid.yaml
At the Moment i only install Landroid-cloud. Not your packeges- no Landroid.yaml
Have now deleted the landroid cloud again and reinstalled it. get a connection but many entries are not available
Evething is back now. But i dont know WhatsApp. I think My cloud Not work becouse i Need 1h mor for have the Dates complet
Both answers sound good.
Thank you.
Hi All
is it possible to change the total time to hours and minutes and the blade time to the same
many thanks
Hi All
just seen that my IP address 192.168.0.142, but my landroid is on 192.168.0.148 confirmed 148 is correct, why would the package pickup the wrong IP address
many thanks
