Hello - I’ve got a Hue Bridge and about 12 Philips Hue lights and 12 accessories (dimmer switches and light/motion sensors). I’m now considering Home-Assistant because the Hue Bridge can only handle 12 accessories (I wished I had realised that before).
If I set up Home-Assistant for my home (probably running on Raspberry PI), would I need the keep the Hue Hub (and therefore still be limited to 12 accessories?) or would the lights and accessories connect directly to the Home-Assistant, in which case there would be no such limit anymore?
Follow-up question if Home-Assistant can control the lights and accessories directly: what would be the best way/protocol to establish such connection? Would it be done over Wi-Fi or Bluetooth? Or would I require a Zigbee hub?
Thanks in advance.
