Would like to have Sunrise and Sunset in SharpTools from Home Assistant
I am still new and learning Home Assistant, and man there is a lot of things that this platform can do. I would like to display the next sunrise and sunset in 1 tile or maybe 2 separate tiles in SharpTools. I would like it to have the date and time be different lines and hopefully the time to display in my time zone which is Central Time.
If someone could point me at least in the right direction it would be greatly appreciated.
The entities card can display attributes of sensors. Times will be correct if your locale is set correctly.
EDIT: I shouldn’t answer questions on the forum when I’m sleep deprived. I thought you wanted to visualise this in HA.
What is SharpTools?
Can entities be sent to SharpTools? I don’t use the Home Assistant Dashboard as I have other smart items that send to SharpTools and that has a Dashboard that is on a tablet in our main area where I have all kinds of things displayed.
https://sharptools.io/ it is a great dashboard tool that you can have many things report to for a nice touch interface for tablets and such.
Yes, when you go through the authorization, you are choosing which entities you want to authorize.
I guess you asked on their forums, did you?
They claim to support HA, so you’re more likely to get help there than here :wink:
