would like to use a more private voice assistant, so i installed almond!
Heard a lot about the ps3-eye as room-mic for an assistant, so i bought one.
Unfortunately the mic from the ps3 is not listed in the configuration of almond.
There is only default and multichannel2000 (what means the AV-receiver, i think).
Can anyone help me to get the ps3 eye running?
Logs when i plug in the PS3 eye:
[ 1547.826534] usb 1-1.1: USB disconnect, device number 6
[ 1547.826975] usb 1-1.1: cannot submit urb (err = -19)
[ 1553.818784] usb 1-1.3: new high-speed USB device number 7 using xhci-hcd
[ 1553.944133] usb 1-1.3: unable to read config index 0 descriptor/all
[ 1553.945831] usb 1-1.3: can't read configurations, error -71
[ 1554.054775] usb 1-1.3: new high-speed USB device number 8 using xhci-hcd
[ 1554.226256] gspca_main: ov534-2.14.0 probing 1415:2000
[ 1556.178154] usb 1-1.3: current rate 19021 is different from the runtime rate 16000
[ 1556.211590] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.230351] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.237864] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.245649] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.253240] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.261290] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.269156] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.276937] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.284873] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.293027] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.300885] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.308869] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.316758] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.324809] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.332776] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.340594] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.348667] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.356492] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.364478] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.372443] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.380050] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.387867] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.395947] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.403980] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.411865] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.419941] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.428028] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.435687] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.443255] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.450946] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.458361] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.466295] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.473784] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.482903] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.490863] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.498299] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.505789] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.513571] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.520909] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.528397] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1561.535793] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
This repeats a few time more and then
[ 1562.252273] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1562.259622] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1562.266884] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1562.274226] usb 1-1.3: 3:1: cannot get min/max values for control 2 (id 3)
[ 1562.450434] usb 1-1.3: current rate 50178 is different from the runtime rate 16000
[ 1562.515055] usb 1-1.3: current rate 517 is different from the runtime rate 16000
[ 1562.519991] xhci-hcd xhci-hcd.4.auto: WARN: buffer overrun event for slot 3 ep 8 on endpoint
[ 1562.520024] retire_capture_urb: 90 callbacks suppressed
[ 1562.520991] xhci-hcd xhci-hcd.4.auto: WARN: buffer overrun event for slot 3 ep 8 on endpoint
[ 1562.521993] xhci-hcd xhci-hcd.4.auto: WARN: buffer overrun event for slot 3 ep 8 on endpoint
[ 1562.522988] xhci-hcd xhci-hcd.4.auto: WARN: buffer overrun event for slot 3 ep 8 on endpoint
[ 1562.523967] xhci-hcd xhci-hcd.4.auto: WARN: buffer overrun event for slot 3 ep 8 on endpoint
[ 1565.843012] hassio: port 8(vethb010af9) entered disabled state
[ 1565.843341] veth0823ec3: renamed from eth0
[ 1565.962056] hassio: port 8(vethb010af9) entered disabled state
[ 1565.963163] device vethb010af9 left promiscuous mode
[ 1565.963181] hassio: port 8(vethb010af9) entered disabled state
[ 1565.963200] audit: type=1700 audit(1629708252.966:217): dev=vethb010af9 prom=0 old_prom=256 auid=4294967295 uid=0 gid=0 ses=4294967295
[ 1566.134858] audit: type=1325 audit(1629708253.142:218): table=nat family=2 entries=15 op=xt_unregister pid=7092 subj==unconfined comm="kworker/u12:0"
[ 1566.134871] audit: type=1325 audit(1629708253.142:219): table=filter family=2 entries=4 op=xt_unregister pid=7092 subj==unconfined comm="kworker/u12:0"
