I have set my inverter to send data to HA through ESPHome via ESP32.
There’s a Read/write registry entry in registry for inverter to grid change voltage.
I can read the value using the following
- platform: modbus_controller
modbus_controller_id: srne1
name: "Inverter Switching Voltage" #name for HA
id: srne_inverter_switching_voltage #id for HA
register_type: holding
address: 0xE022 #register address (see modbus manual)
unit_of_measurement: "V"
accuracy_decimals: 2
device_class: Voltage
state_class: measurement
Since this is a Read / write registry item, can someone please help me to set it up to change the voltage value through Home Assistant?
