I’m trying to log power data to a CSV file from Home Assistant using the Notification to File integration, but I’m hitting an error.
What I’ve done:
- Home Assistant OS 2025.6.1
- Installed the “Notification to File” integration via
Settings > Devices & Services > Add Integration
- Set the file name to
charging_log.csv
(full path:/config/charging_log.csv
) - The file exists and is writable
- No
notify:
section inconfiguration.yaml
- Restarted Home Assistant fully (not just YAML reload)
- Integration appears as:
Integration entries
Notify [charging_log.csv]
1 entity
Automation used:
alias: Log power to file every 5 minutes
- platform: time_pattern
minutes: "/5"
- service: notify.notify_charging_log_csv
message: "{{ now() }},{{ states('sensor.positive_active_power') }}"
mode: single
Error shown when automation runs or I trigger the service manually:
Error: Action notify.notify_charging_log_csv not found
I cannot find the service in Developer Tools → Actions either.
Any ideas what I’m missing?
